Mahindra 2816 Starter Removal
   / Mahindra 2816 Starter Removal #1
papa51
Mahindra 2816 4wd
I'm having issues with my ignition system and have pretty much narrowed it down to the solenoid / starter. I have starter unbolted but can't clear it. There is an approx. 1" tube that looks to be part of the hydraulic system blocking it. The tube branches off to the rear of the pump where it is held in place by 3 bolts, then each end has a rubber hose connection with clamps. Am I safe in removing the tube? Any special instructions on getting the starter out?
Obviously I didn't get much response so here's what I did.....
The problem WAS the solenoid, which is available from several sources for anywhere from 130 to 150$$$$.
Instead of removing the hydraulic line, I removed the muffler and exhaust manifold. It really wasn't that hard to do. Then I took the starter out the top. It was still a little tight for maneuvering but not that bad.:laughing:
Tractor is back in service and I'm heading out to disc a foodplot in my south pasture this afternoon. :thumbsup:
   / Mahindra 2816 Starter Removal #3
Glad to hear you got it fixed.
   / Mahindra 2816 Starter Removal #4
Thanks for posting. I hope I don't need the information but since I have a 2615 (basically the same tractor) I may need this someday.
   / Mahindra 2816 Starter Removal #5
10 years as a dealer we have never removed a starter on a 2615/2816. Have never sold or replaced a starter on one of them. Issues with the 15 and 16 series tractors have been few and far between.
To LAWALLSTRACTOR: I guess either you're very fortunate or I'm very unfortunate. This tractor has less than 300 hours on it. I did speak with a local rancher/farmer who has a 2816 in his fleet of tractors and he had a starter go bad with less than 300 hours. I'm very thankful it was just the solenoid, after pricing starters!!!
I'm still very pleased with the tractor, so far, and hope this was an isolated incident.
But, you might be able to tell me where I can buy a Shop Manual for the 2816???
   / Mahindra 2816 Starter Removal #7
I can help you with that. If you would like me to, just send me a PM.
Galen,
I'm going to need to plead ignorance! What is a "PM"??
Cliff Slaughter
453 Lynn Lake Road
Pollock, Louisiana 71467
   / Mahindra 2816 Starter Removal #9
PM=private message
   / Mahindra 2816 Starter Removal #10
I agree. We have sold at least a couple of hundred 2615/2816 Mahindra's and have had only one starter failure. Obviously it happens, but it sure is rare.
The typical call for a several year old tractor that won't start is "hey, I need a starter, how much $$ and do you have it in stock, my tractor won't start". To which we answer, "clean your battery cables really well and makie sure all safety switches are working, then call me back." With rare exception, that does it.
Champion C80 B (A50322)
Champion C80 B...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
