Buying Advice Time to buy
/ Time to buy #1
dustinfox
Gold Member
New Hampshire
Kioti CK35 HST
OK... I've been pestering you good people for a couple of weeks now learning and researching. You have been very patient with my questions and I appreciate all I have learned. Now it is time to buy. I've decided on the Kioti for because of weight, value, and a reputable dealer just 5 miles away.
The CK27 gear will do the job and personally that is the one I would choose but the wife says she wants the hydro so she can play with it too. That throws a bit of a wrinkle because now I'm wondering if I should step up to a CK30 or CK35 to make up for the parasitic loss. It's a $2,200 difference to go from the CK27HST to a CK35HST. I don't plan on using the PTO at all (at least in the foreseeable future) so I guess they would both do the job.
Which one should I get? :confused2:
/ Time to buy #2
Go for the CK35 HST. I never thought I would be using the PTO but did buy a used post hole auger. Now that we have calves I am thinking of a rototiller to make more seeded pasture for them. :)
/ Time to buy #3
I bought my CK30hst, because my wife also told me to get a hydro drive so she could use it. Believe it or not, she does use the tractor and loves it. Back then, I had test driven a CK25hst, which now is the CK27hst, and my CK30hst. You could feel a big difference with the 5hp upgrade and I also felt the $1,000 price increase. :) The CK35hst, actually 34hp, wasn't available then. There has been only a few times I would like to have more hp but I wouldn't want to go any less. You are correct in that the hst does have some loss over a gear. If you are planning on keeping this tractor for a reasonable length of time, I'd go for the 35 if you can do it but wouldn't go for less than the 30. The weight of the tractor lets you put the hp to the ground and you can push and pull more than you think this smaller tractor could do. If you eventually end up using the pto, you'll have all the hp you need to run matching attachments with ease. Mine runs a 6ft brush hog without a problem but if it gets very thick, I just have to slow down my speed a bit. Someone had posted that Kioti may discontinue the 30 and just go with the 27 and 35. I haven't seen a dealer confirm this though. Good luck on your decision and your wife will like the hydro. :D
/ Time to buy #4
I'm an HST fan. But, I don't understand why a woman can't use a gear. They really aren't any harder to operate. It's not like a car. Especially with the shuttle shifter. And you still have to use the clutch for pto attachments on a CK HST.
You are right in your thinking: CK27 gear or CK35 hst. It's time to pull the trigger!
/ Time to buy
I don't understand either but that's an argument going nowhere... ;)
/ Time to buy
Ok... the winner is CK35HST! Being delivered tomorrow! :thumbsup:
/ Time to buy
Very good point. That's what I have decided! BTY... Do you mind me asking how much you paid for that Woods backhoe?
/ Time to buy #11
Nothing against the CK35 but the CK27 would have no trouble at all with an auger or tiller. IMO the only area that the 35 has a real advantage is in running a bigger mower. Both are rated for five foot implements as I recall though both would run a six foot finish mower easily. It would be easier to "cheat" with the 35 using a six rather than five foot PTO powered implements like medium duty bush hogs.
CK35 vs CK27 with an extra $2000+ in implements such as grapple, diverter valve, rear remotes, topping lift etc. Which would do work most efficiently? I'd argue the 27 with extra specialized implements would get more done (except mowing).
/ Time to buy #12
Actually, w/ the new subcompact coming out next year in @ 22 and 25HP, I heard talk of the CK20 possilbly being bumped up to @ 25hp and maybe eliminate the 27.
Just speculation, nothing for sure.
CONCRETE STATUE YOUNG BOY ON TRACTOR W/ WAGON (A64280)
CONCRETE STATUE...
UNUSED X-STAR 101"x25' BRIDGE PLATFORM (A64280)
UNUSED X-STAR...
2016 KUBOTA RTV-X900 UTV (A64280)
2016 KUBOTA...
2015 TIGERCAT 234 LOG LOADER (A64276)
2015 TIGERCAT 234...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2006 Lexus GS 300 Sedan (A61574)
2006 Lexus GS 300...
