Mowing I hate stumps
/ I hate stumps #2
You can't get someone to heat it up and staighten it? Or find a 20 ton press and straighten it? Enough places around where you live that someone should have a press or torch.
/ I hate stumps
I am going to straighten it friday. I have a large vice. I also have a forge if necessary. I will probably sleeve it also.
/ I hate stumps #5
Just in case it happens again (or to anyone else) there is a cheaper way to repair this if you can weld.
A friend with a 2615 hit a stump and bent his tie rod. He called me, I went over and we removed his tie rod. It looked like a boomerang. I straightened his tie rod back at my garage with a 12 ton press. Three weeks later he hit another stump and completely broke it in half. Since I have the same tractor, I measured the length of my tie rod and made him a new one using a piece of 1/2" thick wall schedule 80 pipe. I cut the threaded ends off of his broken rod (the threaded parts were still straight) and welded them to the new piece of 1/2". That was 4 years ago and its still doing fine. Of course he has since removed the stumps that were sticking up.
/ I hate stumps #6
ouch!
at least it should be a fairly simple removal / reinstall. vs having to take off multi shields, nuts, etc... and no need to have it hauled into a shop for a repair.
if ya have a front loader keep it low to the ground, so more likely to hit something with bucket first. *assumption bushing hogging / using rotatory cutter*
if no front loader. might suggest putting a stronger grill across radiator. so you do not cram something into it. and require a new radiator and grill.
/ I hate stumps #7
JI cut the threaded ends off of his broken rod (the threaded parts were still straight) and welded them to the new piece of 1/2". That was 4 years ago and its still doing fine.
I weld, too - that's a pretty impressive weld. Please share what process you used, what rod, etc.
/ I hate stumps #8
I cut off and saved the threaded ends from the old tie rod. Then beveled a 45 on the tie rod ends and the new piece of schedule 80 with a 4 1/2" grinder. Then butted them together and welded using 3/32" 7018 rod.
For extra strength you could drill a hole in the tie rod threaded end and sched. 80 then insert a smaller diameter pipe or steel rod inside and weld the inner pipe to the outer pipe where the drilled holes are.
I didn't see a need to go that far since 7018 is pretty strong rod and is plenty strong enough.
The weakest part of the tie rod I welded up are the threaded pieces from the old tie rod. They are not as thick as schedule 80 but more like sched. 40
I've attached a rough diagram of what I did.
New/Unused Quick Attach Soil Conditioner (A61166)
New/Unused Quick...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
