How do I convert a splitter and chipper to 3-point hitch use?
   / How do I convert a splitter and chipper to 3-point hitch use? #11
I'm also interested in putting an old chipper on the 3-point hitch. It is an old, old upright Troybilt, a pretty strong piece of original Troybilt. The chipper engine is still fine, but I have been pondering putting the chipper on the tractor. Then I get lost in RPM. I don't know how fast the chipper engine turns, nor do I know how to get the chipper pulley driven by the PTO. I wouldn't want to run the chipper at too high an RPM.
You're gonna kill yourself or at least end up in the ICU. Just don't.
   / How do I convert a splitter and chipper to 3-point hitch use? #12
I've got an 8 HP TroyBilt Tomahawk chipper. It is a tank, but I just made an adapter so I can tow it with my tractor (similar to the illustration). The engine has enough power, so I don't see where it would be worth a PTO modification.
  • Tow Bar.pdf
   / How do I convert a splitter and chipper to 3-point hitch use? #13
I'm about to buy this same chipper, so I'm thrilled to see it works well. What size branches can it process?
I found this thread because the owner said he may use the engine from it and give me the chipper for $40, to which I could convert it to PTO. I think I'd rather have the 8HP engine power it with a 3PH mount instead of having it PTO driven, though.
If the owner keeps the engine, PTO it will be.
   / How do I convert a splitter and chipper to 3-point hitch use? #14
3" in the chipper, 1/2" in the shredder.
I paid about $300 for it used, so you'd still be ahead if you bought an engine for it - maybe used or from Harbor Freight
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2006 Mac Truck CXN613 (A56436)
2006 Mac Truck...
