Basic charging question, I think.
/ Basic charging question, I think. #1
petebert
Outside of Ann Arbor
Just bought a new house with 10 acres and a tractor was included in the deal. It's a Zetor Zebra but I think this is a general charging question so this forum would work.
I've been working on cars for years but am not familiar with how the deep cycle batteries work. I put the volt meter on the battery and it will show 12.2v. When I go to start it I get one crank before it clicks and now with the volt meter it shows 6-7v, let it sit for a few minutes and it will show 12.2 again.
So I jump start the tractor and put the volt meter on the battery terminals and it still shows 12.2, so could it be the alternator? The battery does appear to be old and at the point where they normally fail. I also tried turning the headlights on and voltage at the terminals dropped to 11.8.
/ Basic charging question, I think. #2
Well you are for sure not charging the battery with the tractor, so yes alternator is not working for you. The charging voltage should be at least 13.8 to 14.2 volts. The battery may be about gone now from lack of charging. Put the battery on a charger, check water level if it is that kind, repair/ replace alternator/regulator then decide if battery is going to make it or not and whether it needs to be replaced also.
James K0UA
/ Basic charging question, I think. #3
Yep, something isnt charging it back up.
And 12.2V is a dead battery.
12.6-12.7v is 100%
12.4-12.5v is 75%
12.2-12.3v is only 50% charge
But it makes me wonder...does this thing even have a charging system. Because I question why it even has a deep cycle battery??
Well I assumed deep cycle because it says commercial/agricultural on it, is that not correct? It does have an alternator, I made sure of that. I keep forgetting to check the belt with the motor off but while running the belt flops around quite a bit. I'd never let a car belt run that loose and I have seen cars not charge just due to the belt.
/ Basic charging question, I think. #5
I would first put a charger on the battery and see if it takes a charge (assuming that you have a battery charger). Alternately, set the belt tension same as you would for a car and jump start the tractor, let it run for an hour or so and see if it charges the battery. The battery might not take a charge even if the alternator is working properly. I recently had to replace a deep cycle battery on my boat that would not charge. It would show fully charged but then the voltage was less than 12 volts. You can also take the battery to just about any auto supply store and they can check it for you for no charge. If you have a digital multimeter you can check the output voltage on the alternator with the engine running also.
I would be more inclined to think that you have a bad battery than a bad alternator so work from that direction first prior to removing the alternator. As for the deep cycle battery: Could be that the previous owner put an old trolling motor battery in the tractor that no longer held a good charge for his boat or he may have just bought one as a replacement. They will work for starting battery also.
/ Basic charging question, I think. #6
Sounds like a lack of maintenance all the way around. I would start with the basics.
Check all fluids including checking for water in the sumps.
Check for loose bolts, bad wires, maypop hoses and tires.
Check steering joints, wheel play, brakes.
Most of this can be done while charging the battery. While the belt is loose I would check the water pump for play too.
For the specific problem, recharge battery and tighten or replace belt first then restart and test voltage again. I would expect to see about 14 volts when charging and running. Turn on the lights and see if it will maintain the charging voltage.
With a label showing commercial/agricultural it isn't a deep cycle but is likely just a generic battery. I would check out the overall tractor before spending any money, then if I was going to keep it put the largest capacity battery I could fit. If it doesn't maintain the charging voltage after tightening the belt you will need a new voltage regulator and alternator or depending on the type setup at least the alternator.
/ Basic charging question, I think. #7
Petebert, I think "commercial/agricultural" means the batttery is ruggedized for rough use and may also have higher amp draw (larger internal plates) than regular auto starting batteries. Deep cycle batteries are meant to be charged up and then used until they are almost completely discharged because the equipment that uses them has no ability to charge them. The most common use may be electric trolling motors, but also many dump trailers have pumps running on deep cycle batteries. Normal starting batteries won't last long if they are discharged over 1/2 their capacity on a regular basis. Deep cycle batteries can do this over and over with few negative side effects. Since your tractor has an alternator, it should not need a deep cycle battery, but if it had one, it would be okay.
Are you reading the voltage from the battery right on the battery terminals or on the battery cable connector? If your battery terminals are dirty and you read on the cable, you will see a voltage drop under load. If you put your voltmeter lead into contact with the battery terminal itself, that will tell you for sure if it is the battery dropping or not.
/ Basic charging question, I think. #8
I agree with jinman.. a deepcycle battery is not really for that type of application.. that tractor needs a working charging system.
soundguy
I tightened the belt and still no improvement. It has an internal regulator. I tried testing the voltage at the alternator and it bouncing all over. I've seen this on cars when the brushes wear out so the regulator is trying to compensate. I called my closest authorized parts dealer from the zetor website, about $350 before shipping!
/ Basic charging question, I think. #10
You might want to take the alternator to a local re-builder ( an auto electric shop) in your area...much cheaper than buying a new one...that's what I do.
/ Basic charging question, I think. #11
same here. some even have remanned units that will fit on the shelf.. just swap in your pulley, giv em the core, pay a rebuilt price and walk with it in hand..
soundguy
/ Basic charging question, I think. #12
If you're buying starters/alternators/etc. by "application" you're most often getting taken to the cleaners. If you're shopping for parts like that at the equipment dealer, you're often really getting taken to the cleaners.
Google the numbers on the unit you're replacing. Equipment manufacturers will often spec things, but they very rarely make any of these components themselves. If you have a Bosch, Valeo. Paris Rhone, Magneti Marelli, Nippodenso, etc. there's no reason whatsoever to replace it with something from the closet tractor dealer. That part you're replacing is very likely used on a huge variety of machinery. Buying it at your local dealer means they're adding a premium because you're paying for some imaginary exclusivity....like it was designed and built to fit and operate on *this* model machine.
You can buy a brand-new OEM part online for less than what a rebuilt unit will cost you in town. And since you're buying brand-new, you get to keep your core which can be often repaired easily for a few dollars.
One caveat to online shopping is the knock-offs that are everywhere nowadays. When you Google your part's ID numbers, all sorts of places will pop up with offerings at really low prices. They'll work, but they're not OEM quality. The "trick" they use most often is that they insert "replaces" in their description. If you type in a Bosch number, their part will pop up with the description "replaces Bosch". That's how they get away with it. Yes, their part is "replacing" a Bosch, but they're not replacing Bosch with Bosch.
/ Basic charging question, I think. #13
I agree with brokenot completely. My alternator from New Holland is ove $350, but I saw several online yesterday during a search for around $125. I don't need an alternator, but was doing a search for someone else and discovered this. Also, starters may be over $400 from the dealer, but online you'll find them for sometimes as low as $99 if you ship them your core.
2017 CATERPILLAR 420F2 BACKHOE (A64279)
2017 CATERPILLAR...
1762 (A58375)
1762 (A58375)
Case SV280B (A62177)
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
H&H 500 GALLON T/A SPRAYER (A63291)
H&H 500 GALLON T/A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
