Transmission type selection
/ Transmission type selection #1
saxon
Member
Pelzer, S.C.
Kubota B1550, L3800
Which transmissions are better suited for front loader work,
HST, GST, or gears?
I was thinking about a HST but am wondering about gears.
What about for tilling, plowing, bush hogging, finish mowing?
/ Transmission type selection #2
If your plans are to do more loader work, then HST is probably the most efficient way to go since you won't be constantly changing gears to move material back and forth. If your plan is to do more heavy ground engaging work with plows, disks, blades, then gear drive is probably the better choice. There is a reason why most tractors in the 30hp and up range are gear driven. HST by design is less efficient than gear drive so just keep that in mind.
/ Transmission type selection #3
I Agree.
/ Transmission type selection #4
I have never ran anything but geared tractors so I haven't personally experienced the pros and cons but I have been looking at TBN for a while and I note that there seems to be lots of problems and troubles associated with HST equipment. The operator convienience must make it worth it, I guess, or they wouldn't sell. But other than a clutch once in a great while geared tractors seem to have far fewer problems and limitations.
This is just my opinion.
/ Transmission type selection #5
We have tractors with the old non synchronized geared "crash box", HST, hydraulic shuttle shift and use to own a synchro shuttle shift.
The answer is simple to me at least if you take out the plowing part. For me, an HST is the "easiest" to use, but I would not want to do a lot of continuous plowing.
I have no experience with a GST, so I can't comment on that, but of the types I have used, the hydraulic shuttle shift is the next easiest to use and you can do everything you describe.
I have seen a lot of older problem free HST tractors, so reliability issues are not a concern for me. If they weren't reliable, I wouldn't own one.
One thing about it, I am already used to a HST. That is what my B1550 has on it, that Ive had for 18 years.
/ Transmission type selection #7
don't know where you are, but if big snows and snowblower are in your future, then HST is the choice ...unless you like to replace clutches
/ Transmission type selection #8
I have owned both 2 gear and 2 Hydrostat tractors over a 20 year period, and if Loader work is your primary focus then it is Hydrostat hands down. I have had 0 problems with hydrostat tractors, nor have I heard or read of any. I have heard of many clutch replacements in geared tractors, mostly because of improper use by the operators. If your primary focus is tillage work, then gear is your best choice. Either choice will work for Loader work, but you will have less fatigue, work faster and easier with a Hydro. Hydro is also much easier to use pallet forks, around valuable equipment, less chance of destroying something, and safer to use around personell. Hydro has no learning curve, an inexperienced person can be doing productive work with a couple minutes of instruction.
James K0UA
/ Transmission type selection #9
HST, GST, or gears?
As for mowing, it really depends on what you are mowing. In my case I have so much to trim around, I bought a trim mower, and don't have a need to change speed/direction so I do just fine with a gear trannie. Other factors such as being able to easily remove the FEL are more important for mowing work.
Tilling is so speed dependent HST is probably better but that's a guess in my part.
Your mileage will vary:thumbsup:
/ Transmission type selection #10
As for "tillage work" I meant plowing, or using a disc. As for operating a rotary tiller, I would think a Hydro would be superior, as it involves a lot of stop and go and dwelling at one spot to break up some stubborn soil. Anything that requires stop and go or slow and fast in rapid succession or directional changes will benefit from the Hydro. If you are mowing a straight section then gear is fine, if you are mowing around things constantly and need to slow down and speed up constantly then hydro is better.
James K0UA
/ Transmission type selection #11
you want an HST hands down.because using the clutch all the time will wear your knees out.an you can do most everything with the HST.
/ Transmission type selection #12
I have owned and operated geared transmission tractors, never have used a shuttle shift but I currently own 2 HST tractors (3 if you count the old IH/Cub Cadet 129).
I do a lot of FEL loader work and work a lot on hills so the HST is the transmission for me.
My second choice would probably be a shuttle shift and may add one to the fleet someday.:thumbsup:
/ Transmission type selection #13
Boy, you guys who worry about wearing your clutch out or tiring out your knee are doing too much shifting...more then required for most tasks.
/ Transmission type selection #14
roy you probly havent ever moved hay all summer or ran a baler.doing those things will wear your knees out.thats why i wish they made high hp HST tractors.but they do make the hydro shuttles.
/ Transmission type selection #15
No, I'm a residential operator and I was directing my comments toward those folks.
For you, a reverser transmission would be nice.
But even with a non-synchro gear, I was pretty quick with shifting and can't say I came close to bothering my knees....it's age and abuse wearing out my knees (one of the worst things one can do to damage their knees and feet is stand...especially on a hard (cement) surface.
/ Transmission type selection #16
Are you talking about the HST or the tractors themselves? Posts/threads on bad HST systems are few and far between. I'm not saying HST is perfect but, "lots of problems and troubles"?? :confused:
/ Transmission type selection #17
well see ive done both was on concrete everyday for 27yrs,in an out of a dairy barn.an i tryed to stay outside working because of that reason.my knees are pretty well shot.
/ Transmission type selection #18
You don't say if this is a "professional" tractor (i.e., a full time job) or a "weekend Warrior" machine. HST is ideal for learners/the ladies, but you do lose a bit of PTO power, if you are doing some serious (i.e. baling, chopping silage) farming.
That said, I wish I'd had HST- and GPS and cruise control,- when I was on Old Betsy from sun up to sundown!
/ Transmission type selection #19
I Like HST痴 for the Safety factor, seems to me to be safer or easier to operate on hills. I have gotten into some sticky situations where operating a clutch would have only added to the 菟ucker factor while trying to get things back into control.
/ Transmission type selection #20
Sorry "Pucker"
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
