woodsplitter
/ woodsplitter #1
deerseeker001
Super Member
Central wisconsin
International 2500a with Loader
we are running a splitter off the remotes on the tractor which works great,we just got this splitter and put a control valve on there.everything works great but something needs adjusting because the cylinder don't return on its own.any help would be grateful.
/ woodsplitter #2
What do you mean on its own? did you get a detent valve for a splitter?
/ woodsplitter
ill have to get the name and model and get back to you,the valve looks differant then ones in your pictures,thanks
/ woodsplitter
it was a log splitter valve made by cross manufacturing.the only number i could find was 420001
/ woodsplitter
this will return the cylinder after the log is split
/ woodsplitter #10
/ woodsplitter
this is a brand new valve that's why i don't understand why it don't work properly
/ woodsplitter #12
If you are going to take it apart, watch out for the springs and balls.
Are you pushing the lever hard enough to push it past the detent?
/ woodsplitter
i will check that out maybe that's the problem,didn't know you had to push hard
/ woodsplitter #15
What was the outcome on the splitter valve? Did it ever go into detent on the return stroke?
/ woodsplitter
i want to thank you for remembering me but today was one of those days never got to check it out.we are putting new corrugate siding on the pole barn. i will post reply and let you know if it works,thanks again
/ woodsplitter #17
Are you sure you have the hoses on the correct ports of the valve? P,T,A & B?
/ woodsplitter
I TOOK OFF THE ACORN NUT AND RESET THE THE DETENT SPRING,AND IT DID THE TRICK I WANT TO THANK YOU FOR ALL YOUR HELP.
UNUSED RAYTREE RMA42 HYD AUGER SET (A65055)
UNUSED RAYTREE...
2004 Ford F-150 Ext. Cab Pickup Truck (A64556)
2004 Ford F-150...
NEW HOLLAND 352 FEED MILL GRINDER / MIXER (A64278)
NEW HOLLAND 352...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
UNUSED RAYTREE REDM32-EXCAVATOR MULCHER (A65055)
UNUSED RAYTREE...
2022 EZ-GO ELITE...
