woodsplitter
/ woodsplitter #1
deerseeker001
Super Member
Central wisconsin
International 2500a with Loader
we are running a splitter off the remotes on the tractor which works great,we just got this splitter and put a control valve on there.everything works great but something needs adjusting because the cylinder don't return on its own.any help would be grateful.
/ woodsplitter #2
What do you mean on its own? did you get a detent valve for a splitter?
/ woodsplitter
ill have to get the name and model and get back to you,the valve looks differant then ones in your pictures,thanks
/ woodsplitter
it was a log splitter valve made by cross manufacturing.the only number i could find was 420001
/ woodsplitter
this will return the cylinder after the log is split
/ woodsplitter #10
/ woodsplitter
this is a brand new valve that's why i don't understand why it don't work properly
/ woodsplitter #12
If you are going to take it apart, watch out for the springs and balls.
Are you pushing the lever hard enough to push it past the detent?
/ woodsplitter
i will check that out maybe that's the problem,didn't know you had to push hard
/ woodsplitter #15
What was the outcome on the splitter valve? Did it ever go into detent on the return stroke?
/ woodsplitter
i want to thank you for remembering me but today was one of those days never got to check it out.we are putting new corrugate siding on the pole barn. i will post reply and let you know if it works,thanks again
/ woodsplitter #17
Are you sure you have the hoses on the correct ports of the valve? P,T,A & B?
/ woodsplitter
I TOOK OFF THE ACORN NUT AND RESET THE THE DETENT SPRING,AND IT DID THE TRICK I WANT TO THANK YOU FOR ALL YOUR HELP.
UNUSED PARBREAK RB110-64" ROCK BUCKET (A65055)
UNUSED PARBREAK...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2026 Mower King SSRC 72in Brush Cutter Skid Steer Attachment (A64553)
2026 Mower King...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A65055)
UNUSED FUTURE MINI...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
