New MX5100 on the way!
   / New MX5100 on the way! #1
CJBOTA
Gold Member
Salem, Ohio
Kubota B2620 & MX5100
I closed a deal today on a new MX5100. I'm going with R1 tires, QA bucket, and an FFC 84" Hyd. Angle front blade. This thing caught my eye at the local fair in early September. It was love at first sight. I'm trading in my L3700 with a little over 500 hours on it. The L3700 is a great tractor and I have really enjoyed it, but I need a little more weight and PTO HP to run my new Rears 300 Gallon airblast sprayer in the orchard. I also have three long driveways to keep clear this winter. I am thinking about putting a rear blade on for ballest and the ability to push snow both directions.They should deliver the tractor in about a week. They need to get a bucket in and change the tires.This will be my fourth Kubota. I started with a BX2350, then a B2920, and then the L3700. So far they have all been great machines.
   / New MX5100 on the way! #2
your stepping up in hp nicely.enjoy your new tractor.
   / New MX5100 on the way! #3
I hope you enjoy your new tractor as much as I do mine. So far, 35 hours, it has been darn near purrfect. The effective use of power is truly amazing. The only possible issue is its noise. It is improving with use, however, if you are going to be using it at higher RPM's I suggest earplugs.
   / New MX5100 on the way! #4
you just cant beat the hummm of the MX5100 when she is running at 1500 to 2000rpms.
   / New MX5100 on the way! #6
Congratulations, the MX5100 is a really nice tractor; don't forget to post the pictures.
   / New MX5100 on the way! #7
Congratulations!
When I called Kubota a while back with a few tech questions, the MX5100 was the tractor the gentleman recommended. He was very high on it!
Love to see pics when it arrives.
Sorry guys I'm not big on pictures. Besides, if I took pics I wouldn't have a clue about how to post them. I can tell you this, it's big, orange, and hopefully one bad a## machine. You are scaring me a little about this noise thing. I seriously doubt I will be running it under 2700 rpm's much. Although I won't be using high range much. I do have a slight concern about the light rear end thing. I will run it for awhile and see how things go. If necessary I can always load the tires.
   / New MX5100 on the way! #9
If you will load the tires, and put about 1000 lbs on the 3pt or some less in the form of an implement that sticks way out, like a rotary cutter, then you wont just think it is a beast you will thank it is a MajorTank! You must have ballast to effectively make use of all that power and lift ability. The difference when I loaded my rear tires, and put 750 lbs in the form of a close fitting ballast barrel on the back of my little L3400HST the difference was night and day, and I am not kidding!
James K0uA
   / New MX5100 on the way! #10
We put wheel weights on or fluid in all the tractors we use with a FEL and still use counter weight on the 3PH.
I have yet to own a quit tractor, so any loud noise from the 5100 is not unusual. I now pretty much use all cab tractors.
Irrigation Pump (A52128)
Irrigation Pump...
2012 John Deere 410K (A47384)
2012 John Deere...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52128)
John Deere 700...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
48 Inch Fork Attachment (A50322)
48 Inch Fork...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
