Help me figure out this fuel system
/ Help me figure out this fuel system #1
Fermenter
Southern Riverina, Australia
Here's hoping this will prove amusing enough for someone to chip in and give us a hand!
This old Fiat 615 belongs to my neighbour. Lately it has been difficult to start and prone to stalling. Most recently it lost power gradually and continually over a period of a couple of minutes or so but fortunately he was able to get it back to its parking spot - where it will probably still be in 20 years unless we can get it moving again. Unfortunately getting a mechanic out here is likely to prove too expensive for him.
There are actually 2 problems I need to solve - first is whatever is causing the trouble, and second is fixing what I suspect is a series of errors from my neighbour's unskilled attempts to fix the first. Neither of us know the first thing about diesels, but I'm keen to learn.
He seems to think the problem is due to a fuel blockage somewhere, and that he has also made it worse by trying to start it with various things disconnected thereby getting air in the lines. He's convinced that some major bleeding operation is required, but he doesn't know how or where (although that hasn't stopped him from trying).
I've taken a shot of the fuel system and labelled various points:
1-4 are the lines going to the top of the cylinders. We've checked the lines at the top and we get fuel at each cylinder when hand priming, which makes me suspect that air is not the problem, but perhaps pressure is.
16 is obviously the throttle linkage. 12 and 15 are dipsticks, which were dry inspiring him to fill everything with diesel, including the cap at 11. I'm inclined to think that that whole part of the structure (7, 10, 11, 15, 19) is actually some kind of gearbox arrangement that alters the fuelpump's output pressure based on throttle position - is that correct? Presumably it should be filled with a suitable lubricating oil and not diesel?!
I assume that 20 is the fuel feed from the tank, 13 is a breather/return to the tank and that the primer 14 essentially does the same thing the fuel pump does when the engine is running?
19 is a button that springs out when released, he thinks that may be a cold start button and that it will probably stay in if required.
We normally see some smoke belching from the exhaust stack when turning the engine over, which gives us a clue that something is at least getting to the cylinders and burning. However, we aren't getting anything at the moment - which suggests to me that either there is no fuel in the cylinder, too much fuel in the cylinder, or the glow plug/s (if it even has them, we can't see any electrical connections in the block) are not functioning.
I'd really appreciate any pointers on how best to proceed here!
/ Help me figure out this fuel system #4
Has the fuel filter been changed lately? Also, what about possible gunk/trash/rust in the bottom of the fuel tank??? Might be a good idea to drain it, and then try and flush it out some with clean diesel.
At the very least, if you install a new fuel filter and clean the tank out, you will have eliminated two possible causes.
/ Help me figure out this fuel system #5
is 14 not a fuel pump to bleed or is it just a morning starter
Jon, thanks for your kind offer, I missed you but will try again tomorrow.
I'm not convinced that this thing even has a fuel filter. The fuel seems to be flowing at all the points we've tested though. I agree that a filter is probably a good idea but I'm not sure it will get the tractor started. Could it be that all the injectors got blocked at the same time? What do we need to do in order to clean them?
I have to confess I don't really know the purpose of the priming pump, I assume it is just how you get the fuel up to the injectors if you've let the system drain down / run dry. Presumably the main fuel pump is required to generate short, timed pulses of high pressure to force fuel through the injectors at the appropriate moment?
/ Help me figure out this fuel system #7
Good morning,
I hope diesel fuel was not poured in the crankcase!!!!
You apparently have an indirect injection diesel
engine by the looks of it with a Bosch or
NiponDenzo fuel pump.
Item 5 is the bleeder banjo bolt for the injection
pump and you need to crack that just a little to
bleed it as air can still be in the fuel system if
you do not bleed it there.
It should fire up quicly after that.
I am unsure if item 8 is a a vent for the injection
pumps crank case.
The end of the injection pump should have an
allen plug that is the oil filling plug to add oil
to the injection pump you need thirty weight
oil for this too. The allen plug is metric size
Item 21 is the fuel bowl and it appears to be a
50 micron screen. Please be sure to check the
fuel bowl for dirt and algae.
After you check the fuel bowl and reinstall it pour
one half a can of Seafoam in the fuel tank.
It may be that the fuel is just old and the Seafoam
will clean it up for you.
The lift pump which is part of the priming pump
is behind the hand plunger. There will be a substantial
amount of back pressure when priming the injection
nozzles whem the lift pump is in good condition.
If your beast does not start quickly after you prime the
engine you either have a bad lift pump or the shutdown
is stuck in the kill positiion or its very cold; If you have a
salamander space heater use that to heat the engine up,
they work wonders.
Please try a shot of starting fluid/ether in the air intake
when cranking the engine the next time you try to start it
as the indirect diesels are very cold blooded.
Please be sure the oil bath air cleaner has 30 weight oil in the
bottom base which is the dirt collection pan. There wil be a level
line that is the top limit of the oil level.
/ Help me figure out this fuel system #8
The manual lift pump is for quick bleeding/priming.
/ Help me figure out this fuel system #9
I'm gonna toss my .02 into the ring too.
First and foremost, drain the fuel that your neighbor put in, out of the pump. The diesel will not lubricate the internal parts of that pump well enough for it last long. 12 is the dipstick to check the oil level in the pump. 11 is the fill plug to pour in the oil. It's very important that you drain out all the fuel and replace it with engine oil.
If 20 is the supply line from the fuel tank then 13 should be the line that carries low pressure fuel from the transfer(primer) pump to the filter.
It's hard to tell from the photo, but it looks like 13 takes fuel to a canister type fuel filter that's just to the left of the injection pump. Change this filter!!!!! The fuel should then come from the filter to the injection pump through line 5. Loosen the bleeder screw on top of 5 and pump the hand pump until you get fuel with no air. Make sure to screw the hand pump back down tight when you're done.
If fuel is getting this far, it then enters the injection pump to be put under high pressure and delivered to the injectors through lines 1-4. 1-4 should attach to the injectors in the cylinder head. You'll have to loosen lines 1-4 at the injectors, not at the pump, then spin the engine over until you get fuel and no air coming out of those lines, then retighten the lines.
Air is a diesel system's worst enemy. A diesel will not run if there is any air in the system at all.
If you have all the air out of the system all the way up to the injectors, you should be able to start the engine.
Hope this helps!
Mark
Big thanks to everyone so far, I really appreciate all the help and thoughtful replies. Special thanks go to Jon who talked me through a lot of it over the phone too. What a great bunch of people!
I will take all my notes and have a go at it this weekend and let you know how I go.
Cheers!
2013 FORD F-350 (INOPERABLE) (A60736)
2013 FORD F-350...
2024 Linx 6'x14' Trailer (A60462)
2024 Linx 6'x14'...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
2025 AGT QHT500FL (A60463)
2025 AGT QHT500FL...
iDrive TDS-2010H...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
