Added lights to the ROPS.
/ Added lights to the ROPS. #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
Added a couple lights for plowing this winter. Not sure how much I like the lights though, I might switch to something that has a broader beam. It was nice to have a power and ground already wired to the back of the tractor. If anyone has any suggestions for better lights let me know.
/ Added lights to the ROPS. #2
I like um. You might want to move them inside the ROPS . Might be less likely to knock them off via a tree branch.
Yeah I was thinking that too, if I have enough headroom I might just flip them around.
/ Added lights to the ROPS. #4
Heck or just getting them into the barn door behind the tractor. Was there seperate wiring for this or did you come off the existing light wiring. I took my old yellow flashers off and replaced them with rear facing lights but was looking at what you did as a better option.
On my Kioti there is a power and ground already wired to the back of the tractor. So I just went through that and put in a separate switch. Mine is a 2011 not sure of your year so maybe that is something they started recently.
/ Added lights to the ROPS. #6
I have two in front on the cab and these two on ROPs. The fronts are halogens but these incandesents on the back are sufficient. I try to keep all addons tucked in for close clearances.
/ Added lights to the ROPS. #7
Must be new I have an 02 Kubota and just had wiring foe the rear lights. Will have to come off existing lights or add new harness or get new tractor
Just get a new tractor, I went from a Kubota to Kioti and so far I am happy.... Just think, you would save like $10-15 in wiring!
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
