Dust from mowing
/ Dust from mowing #1
lagunagrande
Member
I own a JD 5205 open station. When I'm out shredding the fields the dust the mower creates creates many problems; can't see, can't breathe, and it gets places it shouldn't be... How do y'all cope with the dust when shredding? I usually mow against the wind but in a large field it is not very easy.
/ Dust from mowing #2
Long sleeves, gloves, crew neck, filter mask & eye protection. Also bandanna under hat to hang down & cover neck/collar junction. I found out (the hard way) poison ivy oils can ride the dust. But not a comfy set up for hot & humid!
Nick
/ Dust from mowing
Ahh so there is no real escape but a cab tractor... Darn! I kick myself for not buying a cab tractor.
Nick
/ Dust from mowing #4
Mow real early in the morning when it's damp, if possible.
/ Dust from mowing #5
Wear a face mask if it gets real bad. Other than that, use compressed air to blow your clothes off BEFORE going in the house. Unless you're single and a slob (because if you're married, you will soon be single!).
Smart advice is to not cut when it's dry as tinder. Early morning like when the dew starts to form (4:30am ish) or couple days after a rain.
/ Dust from mowing
Rain? What is this rain... I live in southern Texas which is in a severe drought :( The morning idea is good but I would need to get rear lights on my tractor.
/ Dust from mowing #7
As others have said, I were a mask, wrap around sunglasses, earplugs, long-sleeve shirt and hat. I think I'm going to try the bandana as someone mentioned next time I mow. My family calls me "pigpen" when I mow.
How far south are you? Are you along the Lower Laguna Madre?
/ Dust from mowing #8
You're dealer will gladly help you trade up. :laughing:
I have nothing else to offer advice wise as the previous posters have pretty much covered it all.
/ Dust from mowing #9
I try to shred in the late afternoon,the winds tend to abate,sun is lower,its cooler.
/ Dust from mowing #11
I had similar issues with my rotary cutter. The dust just made it too painful to want to be out there, and I would wait until it rained before mowing.
I got the idea to use an old tire on the front of my cutter to stop the dust from coming forward. I cut the tire in half, and bolted it onto the front where I had holes already there. My guess is the holes are for chains. The shape of the tire works perfectly for catching the dust and sending it off to the sides. The tire also slides over everything without catching on anything.
Really a simple solution that was cheap and EXTREMLY effective.
Eddie
/ Dust from mowing #12
Better be careful and on the look out. The EPA is gona get ya. Farmers can't make dust any more. O-Bummer took care of that for us other folks.:D:laughing:
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
