Ford 1620 power loss under load
/ Ford 1620 power loss under load #1
tryentolearn
Ford 1620
New to the forum and to diesel's; looking for advice. I have a Ford 1620 with 760 hours. Recently changed the hydraulic filter, hst filter, oil filter, and fuel filter. I bled the fuel lines by turning the bolt out that is on the top of the fuel injector pump (fuel stream shoots out) and then I also bled the lines at the injectors themselves by loosening each inlet on the 3 injectors and turning engine key till diesel was spitting out. Now that's what I did and then shortly within 20 hours of use I noticed a loss of power when under load (mainly going up any incline it looses RPM's and almost dies; if you stop the tractor goes back to correct RPM's). This happens in high, med, and low. During the time it almost dies it puts out lots of smoke and looks like it is starving for fuel. I since checked fuel level, air filter, front of radiator, pulled the fuel filter back off and checked flow seems good, & re-bled fuel lines. Also all my other fluid levels look good. I think it is a fuel related issue. I appreciate any ideas?
/ Ford 1620 power loss under load #2
What color is the smoke. Black smoke would mean it is starving for air. White smoke would indicate starving for fuel. Blueish smoke would indicate lack of compression. You have covered the basic checks. I am thinking possibly bad fuel. Try taking the fuel line off at the pump and make sure you have plenty of flow to the pump. You could have a restriction in the tank.
Bill
/ Ford 1620 power loss under load #3
Most problems with a lack of power on low hour diesel engines is due to lack of proper fuel delivery.
You've checked every thing but the strainer in the fuel tank and the fuel like to the filter. They can get crudded up and restrict fuel flow.
The vent in the fuel cap and get lugged and restrict fuel flow also.
The connections can leak air into them on the suction side of the pump.
A line can be kinked or bent. So check these areas also.
Check the tank strainer first.
Incidently, unless your owners manual says otherwise, I'd start bleeding at the top of the fuel filter and then proceed to the pump and then the injectors, in that order. The pump can spit out residual fuel that 's in the line between the filter and the pump but the filter can be empty. The injectors will spit out that same fuel.
Thanks for the speedy replies. Its hard to say the color of the smoke I would say it could be a light color maybe white, I did hold a paper towel close to it and it left some dark spots on it but I assume there is always some in exhaust. I will stair it down again tomorrow to see if I can get a definite on the smoke color. When I was pulling the fuel filter off earlier I opened the valve and the flow from the tank seemed adequate. And when I open the bleeder on top of the injector pump fuel shoots out of there. Tomorrow I will make sure to bleed on top of the fuel filter first. Can't seem to see the best way of checking the fuel pressure from the injector pumps to the injectors. When I bleed the injector lines should fuel flow a lot or just spit out? Maybe the spitting is just due to the action of turning the key? Although I must say it starts up like always and if I were to just let it sit there it sounds great no hesitation. It moves ok on level grounds with slight hesitation. But under load like going up a hill it wants to die. Can you explain where the strainer is? Is this a visible strainer. My dad had a diesel where there was a strainer you poured the fuel through mine does not have this. Thanks again.
/ Ford 1620 power loss under load #5
Just to be on the safe side, check the air filter. It's probably not the problem, but it might have a critter in there making a nest or be something else like collapsing and blocking the intake. It's an easy check to make sure.
/ Ford 1620 power loss under load #6
Bleed it again, starting at the filter, then the pump, then the injectors. Our old 1100 Ford does that same thing if it's not bled well. You would think the air would work its way out, but I have the best luck just bleeding the whole system again.
/ Ford 1620 power loss under load #7
There is a line that runs from the tank to the fuel filter. Usually the tank end of the fuel line has a valve on it to shut off the fuel from the tank. The strainer is usually a part of the valve assembly and is a a screen type device that acts as a coarse filter. It sits at the bottom of the tank. and is ahead of the valve.
I removed the filter and did the entire bleeding process again. No change. I did feel like when bleeding at the injector lines that 1 of the 3 was not spitting as much fuel. Since I had to get on my tractor to push in pedal so I can turn the key I was only able to see the top of the line where I broke open each line to bleed at the injectors. I messed around pulled off the injector line and blew it out to make sure there was no obstruction. After re-assemble and bleeding again I noticed some bubbles at the base of the injector where it tightens into the engine. I don't have a wrench big enough for it and the crescent wrench is to big. I need to go buy a bigger wrench, size unknown, bigger than my 3/4" and 18 mm. Anyone know the size? Or do I need to take off the injector assembly and get a socket on it? Is there a specific torque setting? Any ideas about this will help. Do you think this could be causing my loss in power?
/ Ford 1620 power loss under load #9
There is a copper washer on the bottom of the injector that acts as a seal. It is not uncommon to see a few bubbles there. It will usually seal up when the engine warms up. This is not what is causing your problem. I would drain some of the fuel into a clear jar and let it sit for a few hours and see what it looks like. Seafoam and Power service are both additives I could recommend to add to the fuel. Was the new fuel filter identical to the old one.
Bill
/ Ford 1620 power loss under load #10
How long have you had this tractor. Was it running fine before you serviced it.
Bill
I have owned the tractor for a year. I did not have the problem before I serviced it but the first time I bled the fuel system after I changed the filter I didn't open the lines at the injectors I only bled it at the pump. Then I noticed the problem with the loss in power.
I never opened the injector lines till I read some forums and realized I didn't bleed the lines at the injectors. Thats when I decided to bleed them again and now I still have the problem. I didn't see any bubbles around the base of the other 2 injectors. Tomorrow I will start it and let it run till hot and see if it stops bubbling. I just figured it could suck air there.
/ Ford 1620 power loss under load #12
Did you bleed the filter first then go to the pump and then to the injectors?
/ Ford 1620 power loss under load #13
Did you bleed the filter first then the pump and then the injectors? It sounds like you have air at the injectors.
The very first time after I changed the filter I only bled it at the injector pump. After this is when I noticed the issue.
Since then I have taken the fuel filter back off and re-bled the system in order of fuel filter first, second at the injector pump, third broke open the injector lines going into engine and turned key till I saw some fuel coming out. Tightened back down and still same issue.
/ Ford 1620 power loss under load #15
hope you have diesel in the tank and not gas
Ok well there has been a change in the symptoms. Today I went out and started the tractor so I could move it out of the way to get my other mower out. When I started backing out the hydraulics felt more responsive. So I took it to my driveway (which is a steep hill) and I put the tractor at 2000 rpm and in low range. I pushed the pedal to the floor and the tractor only went to 1900 rpm and that is what it stayed at up the hill. Then I put the tractor in medium range and pushed the pedal to the floor and the tractor went to 1700 rpm but then recovered and went to 1900 rpm up the hill. Then I put it in high range and pushed the pedal to the floor and the tractor went to 1000 rpm and almost wants to die. I know that in the past that I could run it in high with no problems. So now the problem is changing b/c before I tested it in all three ranges high, med, low and the tractor wanted to die. I even went ahead and mowed with it med range and it seemed fine. But I was staring at the smoke stack wondering if it was putting out normals smoke fuels. You should always be able to see slight exhaust rite? I mean it has to be the rite angle and background to see the exhaust at all.
So is it a blockage that is moving in the fuel system b/c obviously when in high and full pedal you are asking for a lot of fuel. Or is it a hydrostat transmission problem? any thoughts?
/ Ford 1620 power loss under load #17
Seeing black smoke is an indication of unburned fuel, a sign of overfueling.so you shouldn't necessaarily see any exhaust smoke. Sometimes if you idle for a long time and then start moving, you blow out some carbon that accumulates in the exhaust system because of cooler gas temperatures that occur at while idling is not conducive to complete combustion.
Did you ever check the tank strainer and the fuel cap vent as I recommended? They can limit fuel flow if there is some clogging of either one or both. People have had some problems with plastic chips from the tank manufacturing process getting caught in fuel lines limiting power.
As long as you are not really loading the tractor, just driving it around (even climbing a hill is not a heavy load situation) and you are still having an inability to get the engine speed you want , that's pretty indicative to me of a a fuel delivery restriction. So check you cap vent and your strainer and blow back on the line that runs from the filter to the stariner with compressed air.
I just think that your syptoms are indicative of a lack of proper fuel delivery.
/ Ford 1620 power loss under load #18
I keep rereading your original post. You say that you are bleeding the injectors while cranking the engine. Try bleeding them while it is idling. Start the tractor and let it idle and crack each line at the injector.As you crack each line that cyl should go dead. When you tighten the line the cyl should start fireing again. See if there are any air bubbles. I still think it is a fuel issue.
Bill
I agree it is fuel related. I went to New Holland website and looked at the parts breakdown for the tank to filter area. There is no additional screen to check. It appears to be getting air. If I take of my fuel lid on top and try will that verify vent is not blocked?
As for opening the line while tractor is running, is this a good thing for the engine to stop a cylinder?
/ Ford 1620 power loss under load #20
It may not show it in the parts break down but I'll bet there is one there. Is there a shut off valve at the tank bottom? If there is then the should be a screen on that valve. Even if it doesn't there could be some crap and corruption partially blocking the tank exit or the line between the tank and the filter. check it out. What have you got to lose?
