Chains instead of a top link for bush hog?
   / Chains instead of a top link for bush hog? #11
I was browsing around last week on TBN and I read a couple of threads about people who are using a chain in place of the top link for their bush hog. Something about it being better if you are cutting a rough area because the chain lets the bush hog move around more than the stiff top link does. Or, at least that's what I remembered about the conversation. Anyway, in all the discussion about using a chain no one had provided a picture to illustrate this setup. Does anyone have one that they can post to let me see how this works?
I cut a field that my son and his friends use to ride their ATVs in and if they do it after a rain the ruts they leave are treacherous when I'm cutting. The hog is constantly slipping into ruts, out of ruts, and across ruts. I can see how the top link would put a lot of stress on the connection point on the bush hog.
But then on the other hand, I thought that the purpose of the top link was to hold the implement steady?
Thanks,
Mike
The top link is only for when you want to lift the mower up off of the ground. It should be loose when cutting. You set the height of the cut by adjusting your tail wheel, and the height of your lift arms.
Replacing the top link with a chain accomplishes nothing. And since you need the chain to be short enough to still be able to lift the mower, it might limit how much movement you get out of your mower if you are mowing uneven terrain.
How high and at what angle to cut is a topic without a correct answer and subject to personal opinion. Using chains over a top link really isn't something to debate over.
Eddie
   / Chains instead of a top link for bush hog? #12
Here is what I used to use on my old NAA tractor. I had chain for a toplink and also mower height control chains to give me consistent mowing height and take the pressure off the hydraulics. If you have hydraulics that sag, this can make your mower very stable and be able to lift it when needed.
   / Chains instead of a top link for bush hog? #13
Thanks,
Mike
I mow very steep land that is also very rough. I found this system works great with steep approach and departure angles. It allows the rear of the mower to push up on approach and the chains limit the travel of the mower when I go over the top.
Cheers
   / Chains instead of a top link for bush hog? #14
I have my chains running from the 3 point hitch frame to the deck as seen at: http://www.tractorbynet.com/forums/attachments/177784-rotary-cutter-id-please.html
However, the chains now attach behind the gearbox instead of in front of it.
Aaron Z
   / Chains instead of a top link for bush hog? #15
Cheers
Aaron Z
This is the same set-up I have on my Bushhog model 105. ANd the same as I had on an old modern-sunshine cutter. And soon to be converted is my 360 bushhog.
I will note that the chains are much benefit for "rough" terrain. They are mainly for hilly terrain. As mentioned, the approach and departure angles. Having a chain allows the bushhog to follow the terrain better. And like when backing up to a hillside, a chain will allow the wheel to and the rear of the hog to raise up to the angle of the hill, instead of the WHOLE cutter when using a ridgid set-up.
So, I agree with those who say..keep the TL ridgid, add chains from that point down to the deck where the angle "straps" usually are. For a 5-6' cutter, if you have 1 strap, use a 3/8" chain. If you have two angled straps, remove them and use 2 5/16 chains.
Heres a pic of the 105 with chain. And I will also note that having the chain like this makes it easier to hook up as well.
   / Chains instead of a top link for bush hog? #16
My brush mower needed a really slack support chain for it to follow contours properly, but this sometimes allowed the chain to slip under the slip clutch shield when going through steep dips (when the chain would go REALLY slack) and contacting the rotating U-joint. I fixed this problem by installing a retaining bracket on top of the shield and also slid an old bicycle inner tube over the (replacement!) chain to keep it from slapping paint off the shield.
In transport, I just tighten the top link until the chain is taut, then loosen it way up to mow. If the rear wheel comes off the ground when you go over a rise, it will rotate then slam down on the ground as you level out and, eventually, the wheel fork WILL get bent/broken...so, you need either no top support or a really slack support chain.
BOB
   / Chains instead of a top link for bush hog? #17
BOB
The geometry of that cutter is quite a bit different than the ones I have ran chains on. I can see where you were having the problems.
What brand/model is that cutter BTW?
   / Chains instead of a top link for bush hog? #18
While I can see where the chains allow the mower to follow the controu when cutting through a valley, or going from flat to up hill, I don't understand what the advantage is to them when going over a ridge or a high point?
Why even have them on there?
Eddie
   / Chains instead of a top link for bush hog? #19
Eddie
It simply just allows the mower to follow the terrain better.
With a ridgid setup, the mower cannot change angles. It follows the angle of the tractor.
With chains, the angle of the mower can move independently from the tractor. Allowing the mower to maintain a more even cut on rolling terrain.
I really can explain it any better than that. Its just one of them things that unless you have never used a mower with chains, it is hard to understand.
   / Chains instead of a top link for bush hog? #20
most new mowers have a flex link or slotted connection point to allow for that.
soundguy
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
M998 (A55852)
M998 (A55852)
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
Generac XG8000E Generator (A55973)
Generac XG8000E...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
