3-Point Hitch 3 point hitch.
/ 3 point hitch. #1
mickish
Member
I have a b7610 ,can the 3point hitch arms be locked in the up position while im mowing,without Interfering with the up and dowm operation of the mmm.
/ 3 point hitch. #2
No, they are what raises and lowers the mmm. If you were able to lock them in the up position, the mower would also be locked up. What is your reason for wanting the lift arms up?
/ 3 point hitch. #3
I am assuming Mick means the 2 arms connecting the hitch to the hydraulic lift arms. Most cases the arms are detachable and there are some lug locations on the rear frame where the arms can be connected to when not the 3PH is not needed. Just disconnect the pin at the top and use the same pin to attach to the lug. The hydraulic lift arms will still go up and down with the mower motion.
/ 3 point hitch.
The reason I ask this is,i uae a carry all quite a bit and have to hook it on and off every time I mow,which is a pain!
/ 3 point hitch. #5
Then you don't have much of a choice. Is the carry all light enough to be supported by the lug pins? Or would the side to side motion be enough to bend the lugs?
/ 3 point hitch. #6
Actually on the B7610 the 3pt lift arms themselves are what raises the mid-mount mower (it's a ground contact deck.) They have a little bracket on them that runs linkages up to the mower deck to raise it. If the lift arms themselves don't go up, neither does the mower.
/ 3 point hitch. #7
Ahhh.........! Guess I am spoiled by the BX. Only solution then is to remove the carry all Mick was referring to?
/ 3 point hitch.
Thanks guys for all the help.
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
Cat GC25 Forklift (A65579)
Cat GC25 Forklift...
Concrete Mixer (A62613)
Concrete Mixer...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
