chipping trees with the Jimna 6 pto powered chipper
   / chipping trees with the Jimna 6 pto powered chipper #21
I have the same chipper also from Ranch Hand Supply. Great chipper for the money but I did make a few modification. First the feed drum would slip so I made a new one (picture 1). The bed knife - - - not sure what the proper name is but it is the stationary blade - - wouldn't stay close enough so a installed a spacer (picture 2). Finally I found that the blades got dull quickly - - I made some new ones out of D2 steel and had them hardened - - they stay sharp much longer now. I made a couple of other modifications but nothing big. I love the chipper now and use it all the time.
Reggie
   / chipping trees with the Jimna 6 pto powered chipper #22
Holy Cow, that's a pretty impressive feed roller.:thumbsup:
I talked to a local fab shop here and it was going to be very expensive to make up new blades with better steel so I have 2 sets and the dull ones go out for sharpening when I change them out.
Another use for my chipper is making chips for an Alder Smoked Salmon dinner. I strip the bark off a couple 4" fresh cut trees and run them through the chipper. I made 25#'s of chips for a fish fry this Sunday at a friends house.:drool:
Reggie
Nice job on the roller. Where did you find them teeth?? i wouldn't mind doing the same thing.
I now have a fresh set of cutting blades, ill send the old out for sharpening.
   / chipping trees with the Jimna 6 pto powered chipper #24
Hey Johninct,
I have same chipper, it's been great,
I took out the feed drum and cut much more aggressive teeth in the feed roller tooth bars with a mini grinder with a cut off wheel, it works 300% better for feeding ,,, pulls the stuff right out of your hands
Walter t
Got pictures? need to do something like this with mine.
   / chipping trees with the Jimna 6 pto powered chipper #25
Hey Johninct,
Walter t
Yep, that's the kind of thing I was thinking needed to be done. Thanks.:thumbsup:
   / chipping trees with the Jimna 6 pto powered chipper #26
I second that... that new and improved feed drum looks awesome.:thumbsup:
   / chipping trees with the Jimna 6 pto powered chipper #27
grsthegreat - - I made the teeth from a bar of high strength steel. It helps to have a milling machine and lathe in the garage:).
The teeth weren't too expensive but - - - the D2 steel for new blades:(
Hmm, you need to market those things :)
   / chipping trees with the Jimna 6 pto powered chipper #29
That is a healthy looking feed roller:thumbsup:, but I don't think it would have helped me on Saturday. The last end piece of a 5" limb got caught up behind the roller and stopped it, thereby smoking the feed drive belt before I could get it stopped. It's seems that there is too much space between the feed roller and flywheel. This is an 8" Liberty but I think it has identical innards.
I removed the worthless foot release today. No matter how hard I stomped on it, it would not release the drive clutch. I think the long cable has too much flex. I also added a Weasler slip clutch to the PTO. Maybe it would save the 5 drive belts on possibly the independent PTO clutch on my Branson should I bog it down.
   / chipping trees with the Jimna 6 pto powered chipper #30
DeeDubya - - - I found the same problem with the Jinma release. Ended up taking it off and just putting a handle on the release. I also put a stop so I could hold the release handle in the release position for when I get things stuck which still does happen - - but not as often. Mostly when I try to feed too big a large forked branch.
Reggie
2007 INTERNATIONAL 7400 DT466 SFA 4X4 CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
SKLP Windmill Shooting Target (A53316)
SKLP Windmill...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A55787)
2019 John Deere...
Forklift Safety Basket Attachment (A55787)
Forklift Safety...
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
