Welding Table
/ Welding Table #81
Makes me glad they don't salt the roads here.
Seems like they put the cheapest piece of steel right where it carries the most load. :confused2: I could have painted it tho..
/ Welding Table #82
Heres a pic of my welding table I put together a few years ago I got a good deal on the 1/2 "steel plate from my local steel supplier.It's only 3 ft wide by 6 ft long I have a small garage but it's a big improvement over the portable strong built table (folded up just to the right in pic) I had been using.
[/IMG]
/ Welding Table #83
[/IMG]
Prefect table size. How high is it? I am getting ready to start the build of another new one for myself.
/ Welding Table #84
[/IMG]
Looks a lot like mine but I dont have a lower shelf, I store the Mig and Tig under mine.
/ Welding Table #85
Gizmo2 its 32" inches high......I used 1/8 " square tubing for the legs and frame.I was a little concerned about the steel plate it was warped but luckily the heat from the welds drew it down and it sits fairly level now.I used my tractor with forks to set the steel plate on the tube frame. If I recall I think the hardest part was doing the welds on the under side of the table top.I probably should have set the steel plate on the floor and then welded it to the frame but I wasn't sure it I'd be able to flip the table back up right without damaging the concrete garage floor that suckers is heavy.:)
/ Welding Table #86
32", Looks to be higher than that. Seems low to me. My current table is 37" high but I'd rather have your table...
/ Welding Table #87
You can always chop your legs by 5 in;)
/ Welding Table #89
I had my eye on a 30x30" c.i. radiator today. Was thinking 'cutting table top'.. and 'free'.. :D Cast iron should be good for that, no?
/ Welding Table #90
Good idea. Lots of those lying around in New England. I've got one in my basement. Maybe fabricate a stand for a small radiator and you'd be all set at least for non critical cuts.
/ Welding Table #91
I think over did mine... 36"Wx72L 35"H with 4x4 legs and 1/2" top.
SO I HAVE TO KNOW WHAT GAUGE AND OR THICKNESS DID YOU USE FOR YOUR 4X4 SUPPORTS AND CROSS MEMBERS I AM PLANNING ON MAKING A SIMILAR TABLE AND WOULD LIKE TO GO CHEAPER ON MATERIAL IF POSSIBLE, DID YOUR TABLE HAVE ANY FEEL THAT IT COULD TIP OVER WITH SUCH A HEAVY TOP PLATE AND CASTER WHEELS? BY THE WAY I LOVE YOUR TABLE BEST I'VE SEEN YET, CONGRATS..
/ Welding Table #92
Wow. Now that's a welding table. Nice work. If you could do it all over again, is there anything you would change the second time around?
PALLET OF MISC MOTORS AND PARTS (A67714)
PALLET OF MISC...
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
IRanch High-End Tricycle (A64119)
IRanch High-End...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2008 Audi A4 AWD Sedan (A66738)
2008 Audi A4 AWD...
