Flat Tow Backhoe -- no trailer
/ Flat Tow Backhoe -- no trailer #1
nimblemotors
Sacramento, California
Case 530 CK Sold, Ford Ranger DIY Project
I recently purchased an old Case 310B backhoe, it is basically a tractor with a loader and backhoe, it weighs in about 9000 lbs. It has the big 24" tractor tires. I'm wondering if I can flat-tow it, i.e. let it roll on its wheels when I tow it. I'd go slow. It is a bit far to drive it, about 75 miles, at 10mph that would take 7.5 hours. I'm thinking 30-40mph, so only 2-3 hours.. :)
Can the tractor tires/wheels/transmission handle going that fast?
Alternatively, can it be towed by a wrecker tow-truck, i.e. with the big rear wheels on the ground, same kind of issue if it can handle the speed.
Thanks, Jack
/ Flat Tow Backhoe -- no trailer #2
First off I would check the laws in your state and county before I would try that, since tractors are not to be driven at speeds of 30 to 40MPH, i would not think it to be safe or even legal, get a hold of some one to transport it and be on the safe side you could definatlly, hurt yourself or some one else or even worst.
/ Flat Tow Backhoe -- no trailer #5
I like the mentality, but that's not the best idea. All kinds of unsafe.
/ Flat Tow Backhoe -- no trailer #6
I think the tires are not meant to go that fast, I think they are low speed tires and might tear apart.
One of these:
a wrecker lifts the back of a car and lets the front wheels roll, sometimes they put dollies on the front wheels. This is a flatbed tow truck, can one of these be used to carry a 4.5 ton backhoe? i'd think its too much wt?
I bet an equiptment rental place nearby has a trailer you could rent cheap!
not so cheap, haven't found one that handles 10 tons. a place will transport with their driver and equipment at $400 for the trip.
At that expense, I'm looking into buying a old flatbed truck, or even more crafty is buy a cheap clapped-out Class C RV and convert it to flatbed.
They practically will pay you to take away old clapped out big RVs! :)
/ Flat Tow Backhoe -- no trailer #9
No way in **** I would tow it. You will lose a tire, bearing, ect. Also, you would be towing that type of weight with no brakes. I would drive it before I towed it. If it only weighs 9,000# borrow a 14,000# equipment trailer and you will be good to go or a HD Roll Back Wrecker can do it easily. I have a friend that has a towing company and they put things as large as a RV on them.
Chris
/ Flat Tow Backhoe -- no trailer #10
9000lbs is under 5 tons, not sure where you get the 10 ton figure:confused:
It's not only the tires that won't survive the trip, buy the drivtrain may not either...$400 seems like a fair price to me.
/ Flat Tow Backhoe -- no trailer #11
I agree. Last time we had something moved it was either $3 or $3.50 per load mile.
Look at what it cost the transport company to do this. Truck, trailer, driver, fuel, insurance, profit. Its a fair price. I do some transport work and I charge by the hour. If I am not at $60 a hour I am losing money. $75 is more comfortable.
Chris
/ Flat Tow Backhoe -- no trailer #12
I would not want to flat tow that. Like the others have said, none of the drivetrain components (tires, transmission, etc) are designed to go that fast. You could easily do enough damage to outweigh any cost savings.
That said, it weighs 9,000 lbs? A diesel, crewcab pickup truck can weigh 8,000+ lbs. Most wrecker companies should have a rollback truck big enough to move it with. I'd rent a trailer or hire someone to move it.
/ Flat Tow Backhoe -- no trailer #13
Thanks, Jack
Just drive it.
/ Flat Tow Backhoe -- no trailer #14
Just drive it.
If you can't or don't want to pay for hauling it this is the best option. I bet it will do 15mph or so which puts you down to 5hrs. Have someone follow you, stop for lunch along the way, etc and it wouldn't be too bad.
With that said, I have seen an older backhoe being flat towed. It was by a contractor who didn't have a trailer and towed it with a 2-ton truck. Just locally though, not over the distance you are talking. Also another guy, fencing contractor, flat tows his 45hp Ford tractor behind a 3/4 ton pickup. Again, no more than 10-15mi probably. He's been doing it for years so I guess everything has held up. Regardless, I think your only two options should be drive it or have it hauled by someone.
/ Flat Tow Backhoe -- no trailer #16
Just drive it. The geometry on the front axle will not let you flat tow it anyways.
/ Flat Tow Backhoe -- no trailer #17
could you explain flat tow?
Flat towing is generally having all four wheels of the towed vehicle on the road. Usually connected to the towing vehicle by an A frame type tow bar. No trailer, the vehicle being towed just rolls along. A lot of people with big motorhomes tow a small vehicle that way.
/ Flat Tow Backhoe -- no trailer #18
ahh thanks. i checked u tibe and thought that was it.Ive heard of people who set the front bucket in the truck bed and use down pressure to lift it off the ground and then tow it like that. short distances..
My concern driving it isn't just the time, but it is not very safe to drive 15mph when everyone else is going 55mpg behind you, and there is really only one road, undivided two-lane (one each way) highway to where I'm going for 35 of the miles, so I can't avoid this highway.
At least towing it a little faster the impact won't be as large, and I won't be on it when it is crashed into.. it is mostly flat, but there are some dipty-dos and such that you can't see ahead of you, in the worse case someone flys over a hump and there I am.
If a flatbed tow truck will work, that might be an option.
/ Flat Tow Backhoe -- no trailer #20
Id rent a trailer or hire some one. Some transmissions wont oil with the ring driving the pinion. It would really wear the pinion and ring gear to. I wont even roa my old TLB over a mile be fore I load it on a trailer. I have a friend that has a 540 Landscap loader just a tlb with a bucket and a box blade. He cut a hole in the bucket floor ane hoked it over his trucks GN ball. dragging it around locally then it got to being 45 and 50 mph. He fried both planetaries, ring gear and pinion, and killed a few bearings and did some gear damage. Old combines and cotton pickers had knock out axles for this reason to tow them.
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
Challenger 65B/75 Tractor Parts and Service Manuals (A63117)
Challenger 65B/75...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
UNUSED SDLANCH SDLL580 RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64279)
KNOW BEFORE YOU...
