cord wood saw
/ cord wood saw #1
MF1652
Vermont
2016 John Deere 3039R
I started cutting firewood today. Pulled out my grandfathers old saw rig after having the blade sharpened. Cuts like butter now. It's so much faster than using a chain saw to cut firewood. I haven't found any other saw rigs like this one around. The only other cord wood saws I have found hang from the 3 point hitch arms and operate by the PTO. This one rests on a trailer axle and is a pull behind. I don't think it has ever had any real blade protection on it. The only guard above the blade looks to me like it's a tire fender off a trailer.
/ cord wood saw #2
Well, I have looked at that saw for about 5 min and can not figure out how it works? I assume you put the log up on the bench and some how make the blade move?:confused:
/ cord wood saw
The PTO shaft spins the gear box which has three belts running to the blade arbor. That spins the blade. The logs are put on the V shaped table and pushed into the blade which cross cuts the log into firewood sized pieces. It works really fast. You just have to watch your hands.
/ cord wood saw #4
That's a cool set up, but how do you horse the logs round if the tractor is tied up?
Gab, it looks like the bench pivots to me.
/ cord wood saw #5
Thanks for the reminder of the "Good Ole Days"::D
I've not seen one just like that. I'm guessing your grandfather built it?
More common were those that were free standing and flat belt driven.
I remember my Father splitting logs the length with wedges that were too large to handle. Some were split in half and some quartered. The saw we used was totally different. It was made from a Model T Ford. It was comprised of the frame, wheels and engine. A shaft bolted to the flywheel ran to the rear to pillow block bearings where the blade was mounted. No cradle for logs. OH MY GOSH. No one ever lost even a finger.
/ cord wood saw #6
Cordwood saw in action - YouTube
/ cord wood saw #7
Man, that thing us a monster. Bet it's fun to use with a sharp blade.
Actually there was a pic posted on TBN here a while back of a saw like that but I can't find it now, of course.
Have fun and keep your fingers and toes out of the way. :D
/ cord wood saw #8
Most of the old saws like that ran off a belt pulley on the tractor... or big one cylinder engines. Many are still in action at antique farm machinery shows.
Your's appears to be one of the old saws that was mounted to a trailer and adapted to a modern PTO set-up. Pretty cool!
The saws work great for buzzing up smaller limbs, etc... and really well for buzzing up slab wood from a sawmill... then that wood is burned in a steam engine to cut up more lumber! :thumbsup:
Have fun!
/ cord wood saw
I think it was originally belt driven. I suspect my grandfather modified it to be pto driven. My father had rebuilt some of the wood sections when i was a kid. I like using old equipment that was built generations before me.
I bet my grandfather never would have imagined his equipment hooked up to a modern tractor.
/ cord wood saw #10
Looks like a well done home shop project. :thumbsup:
Does not have some of the protection that my Woodsman had.
Hope you are wearing ear protection. There is a reason they are called BUZZ SAWs. :eek:
/ cord wood saw #11
It looks like the blade guard is the upper part of a forage/silage chopper spout.
Could you mount a matching curved section to the pivoting shelf to pivot in the same arc as the existing guard?
As the log is pushed into the blade- the guard will pivot riding on the log.
While moving the shelf (where log is riding) back to position the log for the next cut, the
blade guard will rotate back down to cover the blade.
As with any powered piece of equipment be very careful ! ! ! ! !
T.J>
/ cord wood saw #12
A nice looking setup. That's a real wood cutter...
/ cord wood saw #14
What is the biggest diameter log you can cut clean thrugh ?
/ cord wood saw #15
Massey, We had one 25 years ago that would cut 6" oak as fast as you could push it through. Scary fast to say the least! Powered by a 4 cylinder Wisconson via flat belt.
Paul, Thanks for posting the pics. I still have the saw arbor & table mentioned above but the seized engine is long gone & wood framed trailer is pretty much rotted away. Been trying to decide how to rebuild. A steel version of your trailer setup with PTO drive is in my future. MikeD74T
/ cord wood saw
It will do a little more than 10" but its not fun. I use the chain saw for all the big stuff. A lot of my firewood comes from keeping the fields trimmed back so most of the logs are less than 6". Minimizes the amount of wood I have to split.
/ cord wood saw #20
I have an old cordwood saw, I've never seen it hooked up, its been laying on the ground since I was a kid. Father used it for sawing slabs up before my time. All thats there is the blade/shaft and pulley I think...nothing else. I'm wondering what bearings or pillow blocks you would use to hold the saw fast/tight to run off a chain or something from a slip clutch on pto driveshaft... I could get a picture.
