PEX and floor drain
/ PEX and floor drain #1
wedge40
Have a (new) barn that I plan on putting concrete down.
I will have 5" of concrete with 1/2" rebar spaced 18" and 1/2" or 3/4" pex ran along the rebar for heating the area.. Should I try and put a floor drain in or just let any water evaporate. Seems like adding a drain while running the pex would add to the complexity of the thing.
Wedge
/ PEX and floor drain #2
If possible I would always vote for a floor drain. My concrete pole barn floor does not slope well enough to channel snow melt to the outside. (I asked the sub to make it slope). Plus the apron I had poured at the same time was not tied into the slab so in the winter it heaves and makes a lip that prevents even squeeged water to flow out the door. :(
/ PEX and floor drain #3
I would think that your floor drain lines carrying water to the outside should be placed well below the rebar and Pex for radiant heating. Place forms for the sump (or whatever collector structure you want) and place the rebar and Pex around it. There are countless ways of covering a sump, etc. to allow water to flow in and provide access for removing the crud that will collect over time. Be sure to place the outlet from the sump into the drain lines, above the bottom of the sump to allow for settling of solids. Immediately after liquids leave the sump I think you should include an inline trap, regardless of the eventual destination of the water collected.
/ PEX and floor drain #4
I recently built a 40x40 building with pex heat and 3 floor drains. The drain boxes were the only thing to work around, the pipes were below the 2" insualtion. SO running the pex around the boxes was no big deal
/ PEX and floor drain #5
What are the options for the floor drain boxes? I am doing the same thing as the OP, and have not found a good off-the-shelf drain box option. I want sand trap, and liquid trap so air does not flow into the building through it. Pictures? Links? THanks!!!
/ PEX and floor drain #6
In this state, floor drains in outbuildings are a big no. However, I have Oxygen Barrier PEX heating in my new shop addition and water on the floor isn't a problem, it evaporates quickly when the system is on, in colder months.
My slab is thicker than most because it has to carry machinery. I'm 8" thick, 4 bag mix with 3" of expanded foam below that on a tamped sand base. I used prefabricated galvanized cattle panels in lieu of rebar and stood the PEX off the panels with factory made standoff's.
Last winter I heated the building and the existing (forced air) shop with a 30 gallon water heater set on warm. I have 3 zones, 2 in the mud and 1 running through a stand alone HX with a fan behind it (in the older, existing shop). I kept both areas at 70 no matter what the outside temperature was.
I run straight Cryo-Tek (glycol) with Califfi manifolds, a Taco pump and assorted hardware. I used a remote sensing Honeywell Commercial T'stat with the probe in a thermowell in the slab itself. That way, the t'stat senses the slab temperature and not ambient air.
My total bill on propane for the entire year was about 700 bucks.
I've been looking around and have decided to skip the drain. Like 5030 said, in the winter I'm pretty sure the water will evaporate quick with the heated floor.
Besides I'm not sure what my local gray water requirements are.
Wedge
/ PEX and floor drain #8
Wedge
Midwinter, you'll actually want some water on the floor to turn to vapor to relieve the low humidity. It gets drier than a ragweed fart in my shop in midwinter with the Pex floor.
However, it's the best heat I've ever experienced. Warm feet on a cold day can't be beat and it's a steady heat unlike conventional forced air or radiant baseboard. The mass is warm and radiated heat in a very uniform way.
My wife's barn cats congregate in the overhead door well at the front of the building. The slab extends there, to the apron and it's always warm and dry despite how much snow we get.
/ PEX and floor drain #9
Wedge
I wish I had put floor drains in my garage floor, which is heated with pex pipe. It's too late now, you can't even cut drains after the pour unless you know exactly where the pex pipe is.
If you're in doubt as to local laws, it's worth checking anyway. If it's only to catch snow melt, etc, I'd suggest setting the drain top plate 1/4" below the floor surface and cover with poly plastic when the floor is poured. After the inspection is finished, break out the thin film of concrete and your drain is usable.
My barn drains simply go into the rock under the floor, all they are for is to catch snow melt in the winter.
If the snow is going to melt anyway, what's the difference where it does it??
If you do decide to go with drains, be sure to slope the floor accordingly, or else you're wasting your time.
Sean
/ PEX and floor drain #10
It can't cost much to put at least one drain in, even if you don't connect it outside. It will always be there if do decide you need it. It won't take but a few bucks to put a toilet rough in also. Like it has been said , you can't go back. You can always plumb a sink into the vent from the stool if that is all you want some day.
/ PEX and floor drain #11
Floor drains are a must. That's the beauty of PEX is its ease of installation. I just re-plumbed my entire house with PEX. Easy to work around anything.
/ PEX and floor drain #12
Like I stated in a previous post, here in Michigan, drains in outbuildings are a no, when the drain, drains directly outside. If it's tied into a sanitary system, that's ok. Interestingly, storm water can drain undergrouind and exit at a lower level. Grey water can't.
In my situation, I can't have any slope to the floor because I'm setting machinery on it. The floor was laser levelled during the pouring phase and power trowelled with an epoxy top coat.
My contractor thought I was wacky when I specified 8" of 6 bag mix until he looked in the other building and saw what I was going to set in the new building. It's important that the floor is stable and level as possible. When working in tenths, every little bit helps.
The building I added on to has floor drains (prior to the Michigan Law) with appropriate slope. It's a PITA to accurately level machinery in 2 planes with a floor that slopes.
If I was one of my motorcycles in the new shop in the winter with the PEX system running, a floor squeege to push the water out the door and 20 minutes later the floor is dry and clean.....
In retrospect, I should have run another zone under the parking pad and driveway to the building with a temperature controlled servo valve to keep the snow and ice melted off. It don't take a whole lot of heat/bru's to melt snow and ice.
/ PEX and floor drain #13
I have a floor drain that has a recessed ring around the outside to catch any oil drips etc. It can be cleaned prior to using the drain for washing. I wanted a floor drain for winter snow and in case i ever needed to wash the tractor in the winter. I am not sure a trap is a good idea. If the drain is not used a lot, that trap will start to smell.
Ken
/ PEX and floor drain #14
Ken
Pour some cooking oil in the drain, problem solved. I learned that one from a plumber.............
2014 PETERBILT 567 (A67714)
2014 PETERBILT 567...
TIGER GENERAL  WINCH MASTER BED (A67714)
TIGER GENERAL...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2017 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2017 HINO 268 4X2...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
