Hello
/ Hello #1
timberdave
Alberta
Cub Cadet Ex3200
Hi I'm Timberdave. New to any and all online communities. I have an Ex3200 that I just love. I've had this tractor - my first - for three years now. Unfortunately I may have overestimated its capabilities. Yes it will pull a 9 foot haybine and a square baler. Question is Should I have. It worked fine untill this year when I made too sharp a turn putting most of the tension on the lower left drag bar mounting pin. That mounting pin cracked and I lost all my hydraulic transmission fluid. I did notice it right away and made it back to the shop where all the fluid leaked out.
That mounting pin is part of the transaxle housing -YIKES.
Now I have to split the tractor and replace the housing. A chore I,m not looking forward to but - it is what it is.
Any suggestions
/ Hello #3
Welcome. I think you are talking about a Cub Cadet and if so, try this.I am not familiar with Cub Cadets but maybe this will help somewhat. The following website will give you the specs on your machine and model. TractorData.com Happy Tractoring and good luck.:tractor::welcome:
/ Hello #4
There are also threads on Cub Cadets and various other makes and models here on TBN. Just go to MAIN INDEX and scroll down. Good Luck.
7x14 Utility Trailer (A61165)
7x14 Utility...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
2023 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2023 Ford F-350...
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
