Found this in an old outbuilding - What is it?
   / Found this in an old outbuilding - What is it? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Gents,
I found these together while cleaning out a small outbuilding.
The cyclinder has only one hose, and the other must be a pump because it has heavy electrical wires, and there is fluid sloshing around inside it also.
The square tip shovel is for size referece. I'm struggling with a hyd piston with only one hose. Whats up with that? does it bleed down?
Regardless, is this scrap metal or is this hidden treasure an I should save it to build a ________ ?
Thanks in advance!
Be well,
David
   / Found this in an old outbuilding - What is it? #2
Looks like an electric hydraulic pump and a single action cylinder. I've seen this arrangement for lifting a snowplow. Power up, gravity down.
Bruce
   / Found this in an old outbuilding - What is it? #3
Single action cyl with a DC driven pump. Maybe 12v or 24 v . Tank on other end.
   / Found this in an old outbuilding - What is it? #4
First thing that came to mind was a single acting lift plow cylinder with 12 volt hydraulic pump. If it were me I'd save it but I also save exhausts I find beside the road so I am a little crazy.
Edit: Wow! looks like we all posted at the same time with the same answer.
   / Found this in an old outbuilding - What is it? #5
My vote is a set up for a tailgate lift gate
Bruce
BCP, J_J, Looknlearn,
WOW You TBN'ers are amazing!
So I clarify my question. Is this a "put it on Craigslist for $25" item or is it a "put it in the scrap metal pile" item?
If I get a snow plow I will put it on the FEL and I have 3rd function WR Long electric valve for my grapple now, so...
AmI being dense? Is there something cool I can build with it (once I get a welder etc.?
Thanks again to all three of you.
David
Like on a tow truck? I also found a heavy chain (~6' long) with a big hook on one end that a buddy said was for an old fashioned tow truck.
Thanks,
David
   / Found this in an old outbuilding - What is it? #8
This lift gate pic on the back of a truck is I think what he is talking about. It does look just like one of those cylinders as well.
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2016 MACK TITAN TD713 (A51219)
2016 MACK TITAN...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
