Found this in an old outbuilding - What is it?
   / Found this in an old outbuilding - What is it? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Gents,
I found these together while cleaning out a small outbuilding.
The cyclinder has only one hose, and the other must be a pump because it has heavy electrical wires, and there is fluid sloshing around inside it also.
The square tip shovel is for size referece. I'm struggling with a hyd piston with only one hose. Whats up with that? does it bleed down?
Regardless, is this scrap metal or is this hidden treasure an I should save it to build a ________ ?
Thanks in advance!
Be well,
David
   / Found this in an old outbuilding - What is it? #2
Looks like an electric hydraulic pump and a single action cylinder. I've seen this arrangement for lifting a snowplow. Power up, gravity down.
Bruce
   / Found this in an old outbuilding - What is it? #3
Single action cyl with a DC driven pump. Maybe 12v or 24 v . Tank on other end.
   / Found this in an old outbuilding - What is it? #4
First thing that came to mind was a single acting lift plow cylinder with 12 volt hydraulic pump. If it were me I'd save it but I also save exhausts I find beside the road so I am a little crazy.
Edit: Wow! looks like we all posted at the same time with the same answer.
   / Found this in an old outbuilding - What is it? #5
My vote is a set up for a tailgate lift gate
Bruce
BCP, J_J, Looknlearn,
WOW You TBN'ers are amazing!
So I clarify my question. Is this a "put it on Craigslist for $25" item or is it a "put it in the scrap metal pile" item?
If I get a snow plow I will put it on the FEL and I have 3rd function WR Long electric valve for my grapple now, so...
AmI being dense? Is there something cool I can build with it (once I get a welder etc.?
Thanks again to all three of you.
David
Like on a tow truck? I also found a heavy chain (~6' long) with a big hook on one end that a buddy said was for an old fashioned tow truck.
Thanks,
David
   / Found this in an old outbuilding - What is it? #8
This lift gate pic on the back of a truck is I think what he is talking about. It does look just like one of those cylinders as well.
TAKEUCHI TB235-2 EXCAVATOR (A51242)
TAKEUCHI TB235-2...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
