Loader Replacing a culvert. Questions...
/ Replacing a culvert. Questions... #1
dnels0n
Member
After spending a couple hours hand digging at the upper end of a clogged culvert, I inspected the other end with a big flashlight. The pipe was damaged(probably in the original installation) and was full of tree roots. I am going to have to dig it out or have it done. It measures about 22 feet long and I think 16 inches diameter.
Here is my original driveway project post http://www.tractorbynet.com/forums/attachments/176939-major-driveway-project-opinions-please.html
and here is a link to 3 pictures of the current problem Driveway shots before and after Photo Gallery by Don Nelson at pbase.com
If I get a toothed blade to go on the B3300/La504 loader, can I dig that pipe out? I am concerned about how deep I will be able to reach with the loader blade. Also, this is one of the "best" parts of the driveway as it has a nice layer of packed crush run, if I soak it a day or so will it dig reasonably well?
Suggestions on tooth bar for La504?
Thanks for any help.
/ Replacing a culvert. Questions... #2
You could get down to it probably even without a toothbar. If you have a boxblade drop the scarifiers down and break it up first. Be prepared to get a shovel and hand dig out the sides and under it a little to get it where it will break out. With all the dirt packed in around them they kind of get "glued" in. You'll tear through the culvert trying to lift it out before it will break free if you don't have the sides of it dug out a little. Try to scrape your gravel off and keep it separate from the dirt. Pile what you scoop up off to the side somewhere so you can hit it with the tractor from both sides. I've replaced a few that are about as deep as yours and all i've used is a FEL bucket no toothbar, a shovel, and a chain. Can do it in a few hours.
Thanks, Dusty.
That all sounds reasonable. I figure it will be cooling off a little, at least in the mornings, and I can get this done in the next few weeks.
I went ahead and ordered a tooth bar. I had talked myself out of it twice before so the rule of three(which I just made up) applies.:laughing:
Don
/ Replacing a culvert. Questions... #4
+1 to Dusty's recommendations. The first culvert I did was exactly as he described. The FEL + toothbar did 80% of the work; the boxblade did the rest. Ours took longer mostly because it was a 100+ year old gravel roadbed and packed hard as concrete, but even that opened up with the toothbar.
Be sure you know where any underground phone lines, etc. are. The phone co. is notorious around here for laying phone lines just a few inches beneath gravel driveways going into rural homes.
Also, don't be surprised if you need some extra gravel.
/ Replacing a culvert. Questions... #5
IMO rent a mini-excavator for the day. $200 bucks, and the job can be done in a hour with minimal hand digging.
/ Replacing a culvert. Questions... #6
Do you even need the culvert at all? How often and how much water does it carry? You might be going to a lot of work for little or no benefit. If you put it back are you just going to have the tree root problem again?
Take Care,
Doug in SW IA
/ Replacing a culvert. Questions... #7
I'd hire a plumber that does commercial work to either power rod or hydro jet to make an opening. Then start throwing that root kill stuff they make in there every month or two for awhile when it's not going to rain and let it set for a few days. You'll probably have to do that once a year or so after you get it clear to prevent recurrence. No matter what you put in there it's going to have problems with roots.
/ Replacing a culvert. Questions... #8
I assume you're not going to try and reuse the culvert. When you buy a replacement make sure you get a double wall pipe. The inside will be smooth. They just seam much stronger. Also try to get at least a foot of dirt on top of it.
You may have to remove a fair bit of dirt if you are going to use just the FEL but you can make piles of each type of dirt so you can put the crusher run back down last. I have found crusher run is greats stuff. It packs well but it also is pretty easy to dig up and regrade.
Can't hire out or rent toys when I have the tractor... Maybe after the smoke clears.:laughing:
I have been working on the ditch on that side of the driveway, but there is a good size forested valley that drains at this point. If the ditch doesn't carry enough water, it will cross the drive. I feel better replacing the pipe.
In any case the tooth bar arrives shortly, so installing that is the next project.
Thanks for the replies,
Don
/ Replacing a culvert. Questions... #10
Good for you.
Stuff a 4x4 down the pipe, drive over the top of the pipe and then connect a chain from the tractor to the 4x4. Drive forward, and you'll rip the pipe right out of the ground. MOve the chain to the pipe, then rip out the rest. Clean up the groove with your bucket, drop in a new pipe, then fill it back in.
JayC
/ Replacing a culvert. Questions... #11
Good for you.
JayC
Dang! He makes it sound so easy.
Definitely fix your culvert - you have the technology. "Good fences make good neighbors" and the same is true with drainage. Nothing worse than a washed out road.
-Jim
/ Replacing a culvert. Questions... #12
Don
Sounds like it's time to talk the wife into a new backhoe for the tractor:laughing::thumbsup:
Added an overflow to my existing culvert, a 10 about halfway up next to the old one, did it with the backhoe. After placing pipe in and covering with old gravel and adding new and grading forever seems like I still have a small depression in the driveway were the pipes cross. Can't tell you how many tons of gravel I've added.
/ Replacing a culvert. Questions... #14
One thing with a endloader is that is won't dig very deep on flat ground. If you can get the front wheels going downhill so to speak, you can dig really deep. Does that make any sense? In other words, you will probably have to dig the hole a little wider than you would if you use a backhoe.
I've dug up some pretty solid gravel with my BX without a toothbar, so its not necessary, but it would probably be easier, and less damage to your bucket if you had one. The trick is to break through the gravel in one spot, then you can get underneath it and under mine it easier.
/ Replacing a culvert. Questions... #16
You might find this interesting reading ...and, you might consider HDPE, double-walled and light enough to handle easily.
  • HDPE_Installation_Practice.pdf
I got my tooth bar in/installed and started digging on one end of the pipe. TS Lee is heading this way and we will get anywhere from .5 to 6 inches of rain from that so I thought I would leave the driveway intact for now. As for using the ditch beside the driveway on the upper side for drainage, I guess it will get a good test! Culvert IMG_0349.jpg photo - Don Nelson photos at pbase.com
Yes, you need to dig down at an angle to get deep enough plus, once I start ripping the pipe out, dirt will be less likely to spill back into the hole, hopefully less manual shoveling. Re: Tooth bar. really helps to loosen and dig but then when I want to rake dirt back from the pipe the teeth are just in the way, as you can see by all the lose soil in this pic. The plan is to dig the rest to look like this then remove the tooth bar to clean up some.
I like the idea of a 4x4 in the pipe to help pull it up, will see what I have on hand. In fact I have a metal pipe I might use for that.
Don
/ Replacing a culvert. Questions... #18
You would be a lot better off renting a mini excavator. The wife and I rented one and it took six hours for us to put in 40ft of 18" pipe and that included removing a stump that was in the way. It was well worth the money for the machine.
/ Replacing a culvert. Questions... #19
just some culvert fun I had a few years ago , the toothbar was a great help and to make it a one man job I needed the ATV as an anchor point pulling the clay filled culvert out
/ Replacing a culvert. Questions... #20
I replaced a 12" culvert pipe, about 12' long. I used a backhoe (BX22)...only thing that would break through the compacted driveway material other than a pickax (airport mix, crusher run to some). Even with a BH it was a big job. I replaced the old galvanized pipe with the double wall HDPE type. There are a number of internet sites with guidelines for properly installing a drainage culvert. Here's one of them http://hrpoa.org/Culvert Information.pdf
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2002 Generac SG0035 43kVA Natural Gas Generator (A66734)
2002 Generac...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
Dewalt DG6000 6000W Portable Gasoline Generator (A66734)
Dewalt DG6000...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
