Need a bigger saw
/ Need a bigger saw #21
I've been running a Jonsered which is a Husky by another name and while it has been used mainly on pine it has it has taken a beating. Always give the teeth a couple of strokes with a file every time I fill up.
If you're looking for a TV commercial to recommend one try this:
Stihl Chainsaw Bequeathed - funny commercial - YouTube
/ Need a bigger saw #22
Honestly I am in love with chain saws. I'm not to concerned about the money right now and the reason as to why I am working my way up in the size is because I am trying to build up my experience and skill before spending a ton of money on a pro saw that I don't have the experience to handle and end up hurting myself.
Good Idea working up as skill level permits. The larger 70cc+ saws with longer, wide nose bars and full chisel chain are a whole 'nother league of kick back than what you have been running. I've been using decent size saws for years and every now and again my MS441 will grab something and surprise me.
I grew up in NC where Hurricanes are more common and after every big storm you could just bet on a bunch of people going to the ER after chainsaw accidents. Most had never run a saw in their life and ran out and bought whatever the dealers had, including the BIG saws.
Anyways, hope your new saw works out well for you. My father has an old 039 Stihl (same as the newer 390) and he's used it tons considering it's a mid range saw. Just be careful, wind thrown trees, especially large ones can really do some crazy things when you cut them.
/ Need a bigger saw
Thanks so much for the advice I'm sure it won't disappoint! And as to the hurricane it is just terrible up here there are countless towns were the entire town has no power there are wires everywhere snapped poles. I was running my generator all yesterday let it easy over night ran it all day today. Smelled a burning smell while eating tonight went outside to find it spitting oil into my driveway that was on fire and had to run into it to kill it before it exploded the propane tank. So I'm taking it to get checked out tmrw hoping that it's an easy fix because I can't get a new one around here!
/ Need a bigger saw #24
Yup, I know all about it. Back in the mid-90's when hurricane Fran came through central NC we were without power for 10 days, didn't have a generator back then either....
/ Need a bigger saw
That's rough 10 days without a generator... Dont think the female members of my family would handle that to well... I hope everyone is doing okay down in NC I heard it was even worse there and now they are saying that an other one may be heading our way! All I can say is thank god for my IPhone or else I wouldn't be able to get my chainsaw advice!!
Thanks TBN!!
John
/ Need a bigger saw
Broke in the new saw today...could not be happier!!! Worked great an made quick work of all of my trees barley broke a sweat cutting all of them up! I have one more question for cutting techniques but I'm gonna start a new tread for that!
/ Need a bigger saw #27
Smaller shorter saws aren't any safer. just make sure you take breaks when you're tired and you keep the saw really sharp. If you aren't getting the saw so it cuts like you like it get filing guides and sthil has an ok safety and filing video. Some people who are pretty smart with that stuff have told me to use extra oil in the gas oil mix when working the saw extra hard make it 35 or 40 to 1 rather than 50:1. Opinions vary on that but it's treated me well so far.
/ Need a bigger saw #28
Good thread...
I am currently looking at replacing my 6+ year old stihl 025. I have run about 80 plus cords of wood through it. Some of the stuff we have been felling is 20 to 30" at the but. It has always started on the second pull regardless of weather/warm/cold or down time with gas stored in it for 3-4+ months. I had it in for a tune-up in the spring... wouldn't idle - run. Tech said it has a scored piston. It ran fine for a while but it will not run now. Starts fine but when I give it gas/throttle it dies.... So I am looking at a bigger saw. Tech said basically I burnt out the saw trying to cut too big of logs.
Will look at a larger Stihl or a huska 24" rancher saw. I still have another very old stihl 25 in the shop... needs bar oil reserve tank replaced. When this saw returns I will use it for smaller trees and limb cutting.
Lloyd
/ Need a bigger saw #29
My advise is if you think you will have plenty of use for it then go big. At least 70cc. It may be heavier but it will cut with less force applied by you. If you have to cut from the bottom up you will come to really like the fact that the larger saws need less force to cut.
/ Need a bigger saw #30
I am a fan of the Husky 372 and 24 inch bar. We do use skip chains when cutting in conditions that require frequent sharpening.....less teeth to sharpen.
/ Need a bigger saw #31
I have heard that claim before, but my experience has been a little different.
Sure, there are less teeth to sharpen when you have to sharpen, BUT......
There are less cutters being used to do the work. So in my experience, harpening is required more often.
Dont get me wrong, whe you NEED skip chain, you need it. Like pulling long bars through big wood. It takes less power to keep the saw cutting and you have more room for chip clearence.
But if you have a saw with a 24" bar and skip, IF the saw is big enough to pull full-comp (non skip) I really dont think you are gaining anything. Less time to sharpen, but sharpening more often.
/ Need a bigger saw #32
I know this thread is a few weeks old & the decision on a saw has been made, that said, I would look at getting rid of the 250, leave the 18" bar on the 290 & look for a decent used Stihl 044, 440, husqvarna 272, 362, 365, 371 or 372 or a Dolmar 7900; it will take some patience, but there are deals out there. The newer used saws (from Stihl, Husqvarna, or Dolmar) will cost you a bit more, but I expect there will be newer used saws being sold off before the holiday's. Folks that bought them just for hurricane clean-up will be looking to get rid of them; some of these people will be ones that bought pro saws because they were all that was available when they needed them. My favorite 2 saw set is the Husqvarna 346xp paired with a 372xp but this is a pricey combo. Stihl similar would be the ms260 & ms440 (or 026 pro & 044), but since you already have the 290, you would just be looking at the big brother. Hope your clean-up is done & everything is getting back to normal.
/ Need a bigger saw #33
STIHL 041 AV 041AV CHAINSAW 20 INCH BAR CHAIN RUNS GOOD | eBay
Had 2 of the above for a couple of decades . 28" bars would eat up the oak tree's here . One was purchased at local dealer , Used , Second was purchased on Ebay , Used . Heavy , Yes , But Power was to the Extreme .
Sold Both locally and purchased a new 441 Magnum for $100 less than local on sale price from a person on Ebay who had bought it new , but needed money for something else , ( Family issue's , Bought something he was not suppose to buy with-out checking with better half first .:D ) .
Yes , they are a pain for limbing but being around saws for almost 40 years now , I am used to heavy saws and love having the saw NOT having to work hard in big wood . Sure smaller saws will cut big wood , but it takes a toll .
Fred H.
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
