Need a manual for a b6500d
/ Need a manual for a b6500d #1
NeedAManual
Kubota b6500d 1995
I'm brand new here. I need a manual for a b6500d tractor. Immediately Im replacing hydraulic fluid and do not know where to add fluid to. Is the gear and hydraulic fluid in the same reserve? There is a dip stick under the seat along with a refill port with screwed cap. Thanks for any info that can be provided. Most appreciated.
/ Need a manual for a b6500d #2
Welcome to TBN.
You ain't gonna get a manual immediately, first because it's Saturday night, and second because theres a hurricane. But with that aside, you can order one here, will probably take a few days to get to you: Kubota Tractors - Kubota Tractor Parts & Manuals
You also have the option of posting in the Kubota forum, you may get a quick answer there.
/ Need a manual for a b6500d #3
Don 87 is right on target. Another possible avenue is to sign on EBAY. Under categories, choose agriculture and forestry. Insert Tractor manuals in the SEARCH column. You may find what you are looking for. Happy Tractoring.:tractor::tractor:
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
