Mowing 955 mounting smaller deck???
/ 955 mounting smaller deck??? #1
47chevy
john deere 2520
Well I went off the deep end the other day. Bought the 955...........has the 72" deck and would like to get a 60" deck. Have search and I think that the 755,855 decks will fit my 955 but kinda confused on what arms to use.
Thanks
/ 955 mounting smaller deck??? #2
I was told my 60" MMM deck came off a 955.
(M2734x or M2754x ? serial number)
Mounted right up to my JD855 (1987) with the brackets (front and mid) just fine.
Had to make up a set of lift arms. Easy enough.
Also had to get a PTO shaft for the 855 tractor.
I have a 955 x 60" mmm pto shaft for sale.........
Good luck.
Wyo
/ 955 mounting smaller deck??? #3
Good luck.
Wyo
What was different about the shaft? I thought the 855 and 955 used the same frame, etc.
/ 955 mounting smaller deck??? #4
The '87 855 shared the same frame as the 755. I think around '90 or when the 955 was introduced, the 855 switched to that newer longer frame. This is why early 855s had the fuel tank and air filter/battery switched like the 755 and used the 70 model loader instead of 70A like the 955.
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
LOOK! (A63111)
LOOK! (A63111)
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
