Operating on hilly ground. You level land guys are wimps!!
   / Operating on hilly ground. You level land guys are wimps!! #61
I hate to even open this can,,,, but your first picture is why I don't like a ballast box. Look how high your weight is added.
You know.....you're absolutely right. I completely forgot to lower the box.....:eek:
   / Operating on hilly ground. You level land guys are wimps!! #62
Whoopie...
   / Operating on hilly ground. You level land guys are wimps!! #63
Hills, hills and more hills. Where can I get a tilt meter that goes over 25 degrees? I use a builder digital meter and a spirit level, no use when you are moving.
You dont need more than 25 degrees. Pegged at that side hill on a tractor youre near or past trouble.:)
larry
   / Operating on hilly ground. You level land guys are wimps!! #64
I've posted these pictures before but they apply here. I now mow this area with my JD2210. No worries at all.
   / Operating on hilly ground. You level land guys are wimps!! #65
If the face of your bubble/level gauge isn't vertical you'll get inaccurate readings - in this case, it appears to be reading high.
Oh, and something's wrong with the color settings on your camera - the tractor looks orange. :laughing:
   / Operating on hilly ground. You level land guys are wimps!! #66
When first setting up a tiltmeter, one needs to "calibrate" it against a reference (don't assume you garage floor is level).
I used a regular bubble level (to establish "level" when I installed my tiltmeter.
   / Operating on hilly ground. You level land guys are wimps!! #67
Not just side to side, but front to back. In this case, it appears to be tilted forward and reading 24 instead of the correct 22.
   / Operating on hilly ground. You level land guys are wimps!! #68
When I was a kid my granddad had the dealer put ditchwitch tires on the front of his kubota so he could mow his hills
   / Operating on hilly ground. You level land guys are wimps!! #69
Here is the originally posted picture, rotated clockwise 5 degrees:
attachment.php
   / Operating on hilly ground. You level land guys are wimps!! #70
Just out of curiousity, how do you know it's 22 degrees?
Anyway, yeah...front to back (or, fore/aft as I prefer) should come into play if that degree of accuracy is required or desired.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
