Operating on hilly ground. You level land guys are wimps!!
   / Operating on hilly ground. You level land guys are wimps!! #61
I hate to even open this can,,,, but your first picture is why I don't like a ballast box. Look how high your weight is added.
You know.....you're absolutely right. I completely forgot to lower the box.....:eek:
   / Operating on hilly ground. You level land guys are wimps!! #62
Whoopie...
   / Operating on hilly ground. You level land guys are wimps!! #63
Hills, hills and more hills. Where can I get a tilt meter that goes over 25 degrees? I use a builder digital meter and a spirit level, no use when you are moving.
You dont need more than 25 degrees. Pegged at that side hill on a tractor youre near or past trouble.:)
larry
   / Operating on hilly ground. You level land guys are wimps!! #64
I've posted these pictures before but they apply here. I now mow this area with my JD2210. No worries at all.
   / Operating on hilly ground. You level land guys are wimps!! #65
If the face of your bubble/level gauge isn't vertical you'll get inaccurate readings - in this case, it appears to be reading high.
Oh, and something's wrong with the color settings on your camera - the tractor looks orange. :laughing:
   / Operating on hilly ground. You level land guys are wimps!! #66
When first setting up a tiltmeter, one needs to "calibrate" it against a reference (don't assume you garage floor is level).
I used a regular bubble level (to establish "level" when I installed my tiltmeter.
   / Operating on hilly ground. You level land guys are wimps!! #67
Not just side to side, but front to back. In this case, it appears to be tilted forward and reading 24 instead of the correct 22.
   / Operating on hilly ground. You level land guys are wimps!! #68
When I was a kid my granddad had the dealer put ditchwitch tires on the front of his kubota so he could mow his hills
   / Operating on hilly ground. You level land guys are wimps!! #69
Here is the originally posted picture, rotated clockwise 5 degrees:
attachment.php
   / Operating on hilly ground. You level land guys are wimps!! #70
Just out of curiousity, how do you know it's 22 degrees?
Anyway, yeah...front to back (or, fore/aft as I prefer) should come into play if that degree of accuracy is required or desired.
2010 John Deere TX Gator 4x4 Utility Cart (A49461)
2010 John Deere TX...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
