Converting 3 point trailer mover to log skidder
/ Converting 3 point trailer mover to log skidder #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
I have the bug to convert my 3 point trailer mover to a 3 point log skidder attachment. Attached is a pic of my trailer mover. It's mounted to my Kubota L3830.
I would like to add a boom to the top similar to a Wallenstein FXP20 skidding plate. Check it out here. FXP Skidding Plate - Wallenstein
I'm interested in your opinions and ideas. One concern I have is pulling too hard on the top link. But it would be no different than the commercially available Wallenstein.
I need the specs on the chain slot opening. I will either use 5/16" or 3/8" chain. Probably 5/16".
The project will be designed in AutoDesk Inventor. I'll share the progress with you.
I also plan to install a rear blade or bumper like the Wallenstein. The blade will prevent damage to the tractor and be handy if I ever use a winch with the attachment.
Thanks for any positive feedback... or negative! :laughing:
/ Converting 3 point trailer mover to log skidder #2
I like it .....keep us updated.
Charlie
Maybe this should be in the "build it yourself forum".
/ Converting 3 point trailer mover to log skidder #4
You would have to scale it up a bit, but I did the same thing this past spring. I don't really have a need for the plate though. Mine is just a piece of 1.5" x 1.5" x .25" three feet long to replace the top link with.
Very nice!
/ Converting 3 point trailer mover to log skidder #6
Here's a new one I made last yr. It's a drawbar, old reciever hitch, and some rectangular tubing. When I sold my B7500 last yr the guy saw the hitch I made and had to have it so this one is my new replacement. It has to be one of the handiest thing I've made.
That's a good looking rig! Do you use the chain slots to also pull with or are they just for chain storage? I also like your additional hitch with the small hole for garden tractor class implement (roller, garden cart, etc) Very nice!
/ Converting 3 point trailer mover to log skidder #8
Here is one I made... started with a trailer hitch.
/ Converting 3 point trailer mover to log skidder #9
Thanks, the slots are just a place to put the extra chain rather than let it drag (I got tired of wrapping it around the boom). When I sold my B7500 the guy wanted (had to have) my hitch too so I had to sketch it out and make a new one, of course I corrected a few design flaws. That plate on the bottom was a last minute add on for the little tractor stuff. This does work great, I used my last one to skid 40-50 cord of 12' logs and some whole trees.
/ Converting 3 point trailer mover to log skidder #10
I built this one a couple of years ago.
I welded 4 5/16 grab hooks on the top edge, the screen is 3/4 #9 expanded metal to keep the log ends away from the tractor and tucked safely away from stumps and roots.
Sean
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
207283 (A52708)
207283 (A52708)
2018 Ford F-150 Pickup Truck (A59230)
2018 Ford F-150...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
