Log Skidder for CK 30 HST
   / Log Skidder for CK 30 HST
A log arch would work well for you, and these are the ones I like best, Log Arches - Logrite.com - LogRite Tools LLC
You can use them with your tractor or an ATV.
SR
Yes, a log arch is what I really meant. The trailer with the grapple is way more than I will ever need. So the logrite is a good one? As mentioned above, I don't want a cheap one that is more hassle than it is worth. I think it will be easier on the tractor, the trails and they will have less dirt on them, so easier on the saw and mill.
Thanks to everyone for the help and suggestions.
   / Log Skidder for CK 30 HST #12
Without a doubt LogRite makes the best commercially-made logging arches around. If you are going to buy, rather than make one, the only real question is which of their models to get.
   / Log Skidder for CK 30 HST #13
Unless your forest is really open you'll need a way to get the logs to where you can back the log arch over them. You could use chains and a choker to pull them with the tractor but that requires a space for the tractor to run that's in line with the log and the landing you're pulling it to and as long as the pull. Maybe your forest is open enough (and flat enough) for that but many aren't. That's where a forestry winch comes in handy. Most commercial winches are set up so you can pull the logs to the winch then attach the butt ends of the logs and lift them for dragging them somewhere. Thats functionally similar to the log arch only without the trailer.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
BEFCO 10 WHEEL V-RAKE (A52708)
BEFCO 10 WHEEL...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
CAT 289D3 (A58216)
CAT 289D3 (A58216)
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
