HST Problem Solved?
/ HST Problem Solved? #1
jerkyboy
Upstate NY
So I took my HST apart and found that the bottom of the cylinder block on the pump side scored the port block (not sure if that's what its called) pretty heavily and the cylinder block on the motor side scored it, but not nearly as bad. Otherwise, the inside of the HST looked fine. I've attached some photos but would love to know the cause.
/ HST Problem Solved? #2
How many hours are on your BX? Did it have the filter and fluid changed when recommended by Kubota? I had a service man tell me that the HST is much more sensitive to anything in the fluid than the hydraulic pump.
It has 480 hours and the fluid was changed at 3xx with a Kubota filter and their SUDT2. All fluid changes have been done per factory recommendations.
/ HST Problem Solved? #4
Wow, that doesn't look like 480 hours...very interesting. Did you cut open your filter and see if anything is abnormal?
Deano
/ HST Problem Solved? #5
I had my hst backing plate resurfaced and I replaced both pumps.
Deano
Not yet, but I will and post the results. When I took out the tranny screen and saw metal filings I figured something was up.
Just like having a flywheel resurfaced.:thumbsup::thumbsup: Great idea, I didn't think of that but I've already got a new HST on the way. I just need to figure out what caused it so it doesn't happen again. I'm thinking of replacing the priority flow valve per mattj's suggestion from another post.
/ HST Problem Solved? #8
Do the surfaces look pitted at all or just scored?
What did the slippers on the pistons look like?
Was there any scoring or marks on the swash plates? I.e. Slipper wear plates
Since these are "closed loop" usually when one component (pump) starts to wear it puts the trash into the rest of the components (motor).
Do you use this for plowing snow in the winter? FEL, blade, or blower? Does it sit in a cold building or heated building?
Do you use it mostly for mowing lawns or lots of FEL work.
Just trying to get a feel for use which may help narrow down some possible causes.
Roy
/ HST Problem Solved? #9
You should not have the port block (yes, that is the correct term) "resurfaced", just not a good idea. Just looking at the pictures, it looks as if the charge pressure for the system was low. But I admit that it is strange to see that type of damage on 1 side only. On the BX, the charge pressure is created by the main hydro pump (if I remember correctly) and a regulator valve the splits oil off to steering, pto, and hst. I would check the charge pressure after reassembling.
Roy
Not sure what the slippers on the pistons are. I did a pretty thorough look over of the internals and that is all that I noticed but I'll check again later this week.
The prior (original) owner did use it every winter for snow blowing. He also had it dealer serviced (I have all the receipts) during his ownership. The tractor does sit in an unheated garage, but mine is very well insulated and does not typically go below 30 degrees.
I use it mostly for mowing and I have the Kubota leaf system, which I use extensively in the fall. The problem started happening when I was moving crushed stone (6 ton) and leveling out a small area with the FEL.
I checked the charge pressure before I took it apart and it was 100 psi, which is exactly what the WSM says it should be. Although, I didn't check it with the tractor under any substantial load. I did it with the tractor sitting still and the throttle maxed out....per the WSM. The regulator valve you're talking about is the flow priority valve, which I'm thinking of changing too.
/ HST Problem Solved? #12
I had purchased my tractor with the hst already bad, so I didnt know what caused it to burn up. After rebuilding it, I used it all winter no problem. When the weather warmed up, the hst started to fail again one day while doing some loader work.
The cause was a plugged up radiator which heated the fluid till cavitation occurred and smoked the hst. Fortunate for me , the hst was fine, I shut down the tractor in time and clean out the radiator which was almost plugged solid with dirt and dust.
/ HST Problem Solved? #13
When you get it back together check the charge pressure when driving up a steep hill or doing something that puts a load on the HST. On mine the charge looked fine at a stand still and at full throttle, but start to go up a hill and it dropped like a rock to below 20 psi. With the new flow priority it held fine at my spec of a bit above 50 psi even under the heaviest of loads. May want to check before you buy as the priority valve is around $160.
Also, you did the right move with replacing the whole HST. Its also cheaper as the pump assemblies you showed are around $700 each.
Good luck
Matt
/ HST Problem Solved? #14
Good luck
Matt
Those pump assemblies are less that $200 if if you are willing to investigate,search and stay clear from the Kubota dealer for them.
/ HST Problem Solved? #15
Pistons are what actual pump the fluid in the cylinder bores. In looking at the exploded parts I see that these do not have slippers on them but probably just have a rounded head. Look very similar to what is used in Hydrogear units. Was this head scored or pitted in any way?
If for some reason the charge flow / pressure is limited you would get more chance of scoring when doing FEL work due to higher loads on the HST Vs mowing lawn. The higher the load/pressure in the HST the greater the leakage flow that the charge system must make up.
I have never seen an actual hydraulic schematic for the BX. Basic diagram yes but no detailed schematic.
The questions I have are:
Where is the relief valve for the power steering?
Where does it vent to? Hopefully into the charge pump loop.
Where does any leakage in hydro steering go?
On most priority valves the valve will fail in the condition it provides flow to the priority leg first and then the secondary functions like 3PH, FEL, etc. Have never had one of the Bota ones apart so not sure how they are made.
/ HST Problem Solved? #16
Looks like you are getting some help on this. I would have to say that if it's not dirty fluid then it's a lack of fluid that cause the problem. Along with what others have said I would also check the temp of the fluid after it's been used hard after you get it fixed. Maybe even check all the oil lines and passages to make sure nothing is restricted.
/ HST Problem Solved? #17
Normally I would think of wear in this area as contamination but yours looks more like lack of lubrication. Charge pressure under load has already been discussed - you should monitor that. As for temperature, your hydro works best from 10 cSt to 16 cSt. UDT is 9.3 cSt at 100 degrees Celcius. Once the oil at the working faces gets hotter than that wear goes up at a very high rate. Check your system to make sure oil cooling is doing its job, and if you can, monitor your temp periodically when you are really working it. I use a I-R thermometer that is accurate enough for monitoring something like this.
/ HST Problem Solved? #18
The relief for the power steering is in the steering column and it vents to the charge for the HST. When I took apart my flow priority valve and really looked at it I noticed in the design if the spring fatigued it would at high pressure under load block the HST and give flow to the implements, exactly what its not supposed to do.
When I drove it up the hill the charge would drop and my loader pressure was at full relief around 1850psi and raised the bucket quickly.
/ HST Problem Solved? #19
Matt,
thanks for the info. Kind of sounds like a potential OH Sh*t waiting to happen. So based on this there is the possibility of loosing power steering and charge which I would think would be a big design oooops.
All done with my HST repair. Replaced the unit with a new one and tested it this weekend. Moved 11 yards or topsoil with the FEL and mowed my lawn; new HST is working flawlessly. I did like Matt J and installed an oil pressure gauge to monitor my charge pressure, which stayed consistent during the latest workout.
If anyone is attempting a similar repair, I would highly recommend taking a lot of pics and being very patient.....it's totally doable for the average DIY'er.
FYI, here's a couple pictures of my gauge install.
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
