Shifting On The Fly
/ Shifting On The Fly #1
cassatucky
1996 John Deere 5400 Diesal
So i have a 1996 John Deere 5400 Diesal tractor with a Shuttle shift 4 speed and 4 range option. This is the first tractor i have owned that is a John Deere. It is used, ive only had it for a few weeks though. I have had previous tractors in the past, and also borrowed other tractors from friends and they have all been Kubota. I Noticed with this tractor i cannot clutch and shift gears on the fly and i constantly stall from not having high enough rpms and i end up dumping the clutch and stalling. why wont this tractor shift on the fly like the other Kubotas did?
/ Shifting On The Fly #3
/ Shifting On The Fly #4
You should be able to able to shift speeds on the go, but most be stopped to shift ranges. Note you MUST BE stopped to put it into Park.
That's what I thought too, but according to TractorData.com, there was a 9 speed (3 range) collarshift transmission available with the 5400. This is a non-synchronized (gears as well as range selection), so I'm wondering if that's what cassatucky actually has.
Cassatucky...if you have the shuttle (reverser) transmission, you would have a reverser lever just to the left of your steering wheel...do you?
/ Shifting On The Fly #5
Roy, I also first looked at tractordata.com figured the 4 on the range was a typo and should have been 3. If he had collarshift there would have been some grinding mentioned.
Tractordata also shows John Deere Top-Shaft Synchronized - Three gears (1-3), plus reverse, in three ranges (A-C). Gear shifts are synchronized using the clutch. Tractor must be stopped to shift range. The description matchs what is on my tractor, but on my tractor it is call SyncShuttle.
It could be the TSS Reverser that would be nice since it is a wet clutch.
2022 EZ-GO ELITE...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2007 PETERBILT 386 T/A 6X4 SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 386...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
