25 acres & trying irrigate hay
/ 25 acres & trying irrigate hay #11
I looked at a Kifco pto pump and reel recently. The reel was nearly new but turned out to not be available although I was ready to purchase the pump. My acreage is in three separate but adjacent areas which presents additional distribution problems. I am currently thinking about permanent trenched sprinklers. With such a small area it looks like a single reel may cost nearly as much as trenching, piping, and valving the very sandy soil on my place. Moreover, the reel would need tending and positioning. Center pivot just doesn't look like a sensible solution on my property. I assume permanently piped sprinkers could be controlled with valving and electronics. It is likely that an added adjoining 20 acres will be leased and irrigated. That acreage WOULD need portable watering since I would not do permanent irrigation on rented property. Got any advice???
Around here hayfields are surface irrigated. My neighbor grows alfalfa on 20 acres irrigated either by government water from the ag canal system here in the Great Central Valley or, during drought years (2007-09) when the govmint rationed canal water, with well water ( about 100 ft depth, pump is run by a stationary diesel salvaged from an old Nissan). Flow is around 600 gal/min from the well and to irrigate 20 acres takes about 70-80 hours of pumping at 1-1.5 gal/hr fuel burn.
Surface irrigation requires a lot of preparation: rip the soil to 24" depth with a D7 Cat pulling a double shank subsoiler to break up the hardpan layer(s); laser level the field and slope it so the water flows correctly from one end to the other; plow checks into the field to keep the water flowing in one direction; install the main pipe and valves to tap the pipe at 10-20 ft intervals; then fertilize and plant.
Don't know if this helps, but good luck in your haying project.
Flusher, Thanks for the explanation. What is meant by "surface irrigation"? Is this just flowing water onto the top of the soil and directing it across the field or is there a pressurized sprinkling delivery? Also, my hay is already in (Coastal Bermuda) and my soil is totally red sand 15'+ deep over bedrock. Other than hay and a small cattle herd it was last cropped in peanuts probably 20-25 years ago. It's so well drained that standing water goes down like a sieve so my guess is there is no hardpan situation. In your friend's situation, how much water is applied per acre per session per cutting for the 70-80 pumping hours?? Thanks again.
Wally
Dan, That would be a good way to try out hardware and ultimately make a more informed purchase IF rental hardware is available in the season. Don't know yet what would be available here in central Texas or how costly a rental would be.
Wally
/ 25 acres & trying irrigate hay #16
Wally
Yep, it's flood irrigation (a sheet of water, ideally, flows across the field from the high side to the low side, grade is about 1 percent). No sprinklers. The main pipe from the well (or whatever water source) is pressurized and runs along the high side of the field. That pipe has hand valves every 10 feet or so which are opened when irrigation is needed. The flow rate is adjusted so there's minimal runoff at the low side of the field. This arrangement minimizes the amount of pipe needed, but at the cost of a lot of work to level and slope the field initially before planting. IIRC, there's less evaporative loss with this type of irrigation than with sprinklers.
He irrigates 20 acres of alfalfa once between cuttings (deep watering) for about 70 hours at 600 gal/min which is 126,000 gallons per acre (0.38 acre-ft) if my math is correct.
/ 25 acres & trying irrigate hay #17
Here are some photos of that alfalfa field when the irrigation system was being tested.
The main pipe is underground. The concrete caissons provide access to the main valve.
You can see two of the long checks that have been plowed into the field. Separation between checks is about 105 ft.
Water flowing from one of the taps in the main pipe.
Hope this helps.
/ 25 acres & trying irrigate hay #18
Do you have to worry about environmental regs? Up here a farmer was fined for diverting water out of a small river.
/ 25 acres & trying irrigate hay #19
I can't imagine watering 25 acres with a tractor operated pump.
MarkV
You just have not looked at the right pumps ...
Also look at Smith Irrigation equipment ...
Very good point indeed ... check that out. Best to have a private source.
tcreeley, Yes there are regulations. I own riverfront on the Brazos and have deeded riparian rights to (the reasonable use of) water for domestic purposes. When needing more water as for irrigation I need to contract with the Brazos River Authority for a requested amount of acre footage of water, currently about $43 per acre foot.
Butler MFG Water Tanker (A61307)
Butler MFG Water...
1998 POLAR TANK (A60736)
1998 POLAR TANK...
HYDRAULIC TANK WITH COOLING SYSTEM (A60736)
HYDRAULIC TANK...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
Atlas HA-ECGO 3pt 5' Box Blade (A60462)
Atlas HA-ECGO 3pt...
