Mahindra 3016 4WD review
/ Mahindra 3016 4WD review #1
scooterdoc
Mississippi
Mahindra 3016
Hey ya'll,
Noob here, hope this is posted in right place. Just thougt i would put in a review of my new Mahindra 3016. Overall, really happy with it. I am a newbi and this is my first tractor, but have already worked the machine pretty good. to keep this short and sweet, basically,
Pros: Like the 4wd, great FEL, Like the pulling ability when in low and 4wd (interpret this as I havent got stuck yet). comfortable seat. simple display (i like simplicity vs. bells and whistles which go bad. service areas are easily accessable. Price. the package came complete and could not be beat by any local dealers.
Cons: would like arm rests on the seat (I usually spend 2-3 hours on tractor when i use it and i am getting lazy in my old age.)
in summary, I would say, I am no expert, but it is a really easy to use, strong, and i have no problem recommending this tractor. hope this helps. shoot me any specific questions, i will be happy to answer them if i can.
S.D.
/ Mahindra 3016 4WD review #2
Hey ya'll,
S.D.
I was interested in this model a couple of questions
is this a shuttle or hydro?
did you opt. to get the pallet forks?
and also what was the price?
randy,
I got the shuttle shift.
i would have to look at the reciept, because i bought a package deal which included (3016 4wd, fel, box blade, 5' bush hog and 20 foot tandem trailer)
for 18k hooked to the truck.
one additional "CON" that i would associate with the tractor is the 4wd engage mechanism. being limited slip, when you need all four wheels to turn, you have to step on a small lever underneath the right foot. you almost have to stand up in order to do this. i have alot of unlevel ground to work, and sometimes engaging the 4wd can be a little tricky. once engaged, it climbs very well. it could easily be fixed with a welded on pedal or extension of some sort. but other than that, worked it pretty hard today for about 6 hours and am still pretty happy with it, feel confident in recommending it, and it has done everything i have asked of it.
hope this helps.
r
S.D.
/ Mahindra 3016 4WD review #4
Sounds like you got a great package for a great price.:thumbsup:
After extensive research (used vs. New) luckily I don't have any buyers remorse. Pretty happy with the whole experience. Thanks for the kind words.
/ Mahindra 3016 4WD review #6
very good price, i think i will get a price.
thanks
/ Mahindra 3016 4WD review #8
I'm pretty close to pulling the trigger on a 3016. Still trying to decide between that and a 2516. Any thoughts on why you chose the 3016 vs the next size down or up? How much acreage are you dealing with?
I'll be checking out the Mahindra dealer in my area tomorrow.
Thanks.
/ Mahindra 3016 4WD review #9
Got to the dealer a little too late yesterday, and they were closed, dang-it! But got a couple pics and unless I'm really disappointed when I get to do a test-ride, then I think this is the one.
Probably go with the shuttle instead of HST. Always thought I'd be HST, but the more I read about the shuttle on these Mahindra's the more I think it fits my style.
/ Mahindra 3016 4WD review #10
Good looking rig.
/ Mahindra 3016 4WD review #11
I like the new headlights on the 3016. Looks nicer than the headlights my 2816.....brighter I would bet also.
billy,
chose the 3016 simply because it was the most tractor i could afford. all the research here recommended buying bigger than you think you need. it was the next size up from what i thought i needed. very happy i went up a size.
currently dealing with 40 acres hilly country, so 4wd is a must. so much so i am contemplating on putting a winch on the front to pull me out of stupid situations that i keep getting myself into. :laughing:
s.d.
/ Mahindra 3016 4WD review #13
billy,
s.d.
Scooter, thanks, great info. I think I'm one size larger than I need with the 3016 as well, and at about my max budget. Still leaning this direction vs my alternate of Kubota 2920. I think the Mahindra is a lot more tractor for about the same price.
I have 11 acres, of which about 4 are cleared. I need to clear a fairly large thicket between two areas and smooth out the whole property. Also need to clear out some overgrown walkways through the trees, and pull apart a fairly large debris pile (trees, shrubs, etc) from when the big tractors came through preparing the home site. I think the 3016 will do all this for me. So might the 2516 or Kubota 2920, but the 3016 will give me that extra umph I need occasionally.
I do the test ride this weekend, and will make my final decision. Any other thoughts or recommendations before I pull the trigger?
Thanks,
BC
/ Mahindra 3016 4WD review #14
I would not hesitate buying the 3016 and here's why. You have plans currently for what you want to do with your tractor and how you think you will use it for which the smaller tractor will also handle. What is not accounted for is contingencies that you are not yet aware of because they have not surfaced yet. It is then that you will wish for the larger machine with the larger tires and more weight and a bit more grunt. Yes these contingencies certainly may be scarce in comparison to the daily usage but they have the uncanny knack of popping up more times than would be believed at fist.That is why the sage advice of buying the next size larger tractor than you think you will need is constantly given as just about everyone who has owned one has wished for the next size for that unexpected situation that inevitably pops up with this kind of stuff we do on the land that we own.
/ Mahindra 3016 4WD review #15
You might want to also check your PTO requirements. Big reason I went with the 2816 over the 2516 was it offered a live PTO. You can get by without it but it's much easier to run the mower and some other attachments.
Other big reason was that the 2816 has a 60" bucket and it seems to be easier to find 5' attachments where I live.
Good luck on the test ride....
/ Mahindra 3016 4WD review #16
Did the test ride today and I was pretty impressed. The bucket was very easy to maneuver. The HST model was a snap to get the hang of riding around. I also tried the Shuttle Shift, and although I learned to drive on a stick, I found it a bit tricky to get it to do what I wanted it to do -- I'm sure I could get the hang of it after a while, but the HST was just so much easier to run. Seat was comfy, engine was quiet, overall smooth, nice ride.
What's not clear to me after I left the dealership was whether there is a mid-point PTO -- I assume this is needed for a mid-mower -- is this on the 3016? Looking at the specs it's hard to tell, looks like an option, but I don't see any mid-mower offered. Also do these usually come with a protective grill in front of the radiator?
/ Mahindra 3016 4WD review #17
The mid PTO, and grille guard are both optional and the mid mount mower is available.
/ Mahindra 3016 4WD review #18
I'm getting really close on cutting the deal. Just down to a few odds and ends like a grill guard and whether I go with a canopy or not. They've been pretty flexible on the cost, and I think it's pretty competitive based on what I've seen here on the forum.
Question for any 3016 owners, do you know about what the top-speed mph is on these things? I'm guessing about 15, but it doesn't state that in the specs. Funny that Kubota states this in their specs but Mahindra doesn't.
/ Mahindra 3016 4WD review #19
And why would you want to go that fast and what would you be pulling?
2000 JOHN DEERE 310E BACKHOE (A62129)
2000 JOHN DEERE...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2016 Chevrolet Silverado Pickup Truck, VIN # 1GCRCNEH0GZ236549 (A61165)
2016 Chevrolet...
2010 Case 580N (A60462)
2010 Case 580N...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2021 Kubota SVL 97-2 Skid Steer (A61166)
2021 Kubota SVL...
