And yet another JD 2520
/ And yet another JD 2520 #1
lost in wisconsin
Wisconsin
John Deere 2520 (2011)
About 2 weeks ago, we took delivery on our 2011 2520. Like many others here, we took advantage of the $2500 promotion and signed the papers on May 31. The 2520 was on the lot and if it had not been there when I stopped a week prior, I doubt we would have considered purchasing a different tractor (we traded in our 2007 2320). It took awhile for the FEL and PHD to get to the dealer which really was no big deal, as we just continued to use the 2320. So in the end, we went with the FEL and PHD as our 2 attachments, ordered a PTO shaft for our FM snowblower (the 2520 is a bit longer than the 2320) and worked an iMatch into the deal.
We only have about 5 hours on the meter to date and the only negative comment I have thus far, is the area behind and under the seat is no longer enclosed. On our 2320 it was and I used to place my gloves, tool, sunflower seeds, etc in that area. But not really a big deal and I did immediately notice the quicker response for loader controls.
Here a few pics & mods I have made to date and yes...I am aware I need to change my signature now. :thumbsup:
/ And yet another JD 2520 #2
youve got a nice looking tractor there.
/ And yet another JD 2520 #3
Very nice rig.......I have a 2520 myself, and am very happy with it.
I like your toolbox, where did you get it if you don't mind my asking? It looks like a pretty sturdy box, and seems to fit nicely behind the seat. I haven't seen any like that before.
Is it just bolted to the heavy plate behind the seat? I really want to put a toolbox on mine, and it looks like that plate behind the seat is about the only spot. Yours seems to fit, even with the "Slow moving Vehicle" sign left on.
Looks like you have to take it off with the post hole digger on.
REV
rev,
Thank you. I am very much enjoying the 2520.
It is an ATV/Tractor Universal Toolbox which I bought at Fleet Farm. I noted you are in Canada so tonight I took 2 pics of the box the toolbox came in. It is made by Larin & PN MTB-16G. Below is a link at Fleet Farm's competitor Farm & Fleet website.
Larin Green ATV / Tractor Tool Box (16") at Blain's Farm & Fleet
For mounting, I used an existing hole (RH side)on the plate behind the seat and drilled a hole on the left hand side and used a #12 self tapping metal screw (see the 3rd pic).
Regarding the SMV I added a couple of washers on the 2 bolts between the SMV sign and bracket to ensure there wouldn't be interference when opening the lid of the toolbox.
I thought about the PHD when I mounted this but my primary concern was the 3pt arm. If you look at the orgininal pics I posted, I have about 18" of clearance between the bottom of the auger and the ground. I am hoping when I have the PHD mounted and not lifting it up completely, I can still keep at least 12" of ground clearance b/n the auger and the ground and also not slam it up against the toolbox. Once I mount PHD again, I will test my theory and can post some pics.
I hope this helps
/ And yet another JD 2520 #6
lost in wisconsin Nice looking tractor :thumbsup: I also took advantage of the $2,500 incentive. Working great so far with the minor bump in the road of a metal hydraulic line failure that was fixed very quickly by the dealer.
Realy like the additional lighting on your "light cages". That's probably my next two additions.
small,
If you decide on the lights, it would be better (as in cheaper)to order directly from JW Speaker than through JD.
Let me know if you decide to proceed and I can give some PN's if you need it.
lost
/ And yet another JD 2520 #8
Thanks lost
I took a look at their site it looks like to get price quotes you need to contact the company. I didn't see any prices listed?
Yours appear to be the led version?
/ And yet another JD 2520 #9
Thanks Lost, for the info on the toolbox. You're right, I'm in Ontario, Canada, so I will check to see if there are any "Farm Fleet" Dealers around here. Hopefully I can find a source for the box, I really like it. it looks great, and is exactly what I had envisioned.
REV
/ And yet another JD 2520 #10
Those are really nice looking lights.:thumbsup:
I think I may go with those too.:)
...and congrats on the new machine.
Greg
smalltown,
Ours are not LED, when I was originally looking last year for our 2320 w/ 20 amp alt, I considered LED's. I found them to be expensive and the review by many (but not all) was they did provide the light a standard halogen does. Mine are JW Speaker Model 7100 floods. Below is the info if you decide to order through JD.
-Forward Light Kit PN LVB25546 (2 lights)
-Rear Work Light PN LVD25547
lost
/ And yet another JD 2520 #12
smalltown,
"Mine are JW Speaker Model 7100 floods. Below is the info if you decide to order through JD.
lost
RE the JW Speaker 7100's, they are offered with different bulb configurations, H9, 862 and 9005. The H9 outputs the most lumens. Which version did you buy and how do you like it? You said you purchased the "flood" version. Also, are all three lights (two forward facing and one rear facing) the same?
urban,
When I get home this evening, I will take a look on the bulb insert/mounts to see if there is an indication to which version of the 7100 I have. I assume you were looking at the spec sheet I have attached.
IMO more light is always better and I like the fact that I was able to use the existing 'plug and play' wiring harness. I also like that I am able to control these lights with the existing switch. I need the additional lighting for when I snowblow early in the morning or at night as the factory installed hood lights are partially blocked by the FM snowblower. Now, I may change my tune if I were doing extensive FEL work at night and wanted direct control of these lights. But my what I need to for right now...it suits my situation well.
I will get back to you tonight or tomorrow.
  • model-7100-4-x-6-oval-halogen-work-light.pdf
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2012 Toyota Avalon Sedan (A61569)
2012 Toyota Avalon...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
(1) UNUSED 10-16.5 TIRE W/6 LUG RIM (A62130)
(1) UNUSED 10-16.5...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
