sub soiler broke top link
/ sub soiler broke top link #1
derek01
I broke the top link while using a subsoiler with my Kioti DK40SEH HST I guess I did something wrong with the 2nd lever that adjusts the float for the 3 pt hitch any suggestions as to what I did wrong and what I should do to avoid this again, I imagine I could have done more damage then I did.
/ sub soiler broke top link #2
I might be wrong, but I don't think the float would help much with a subsoiler. Either way it it catches an imovable object(root,rock/etc) something is going to give & I would rather it be a top link than anything more expensive. I think you will have to run it a little slower & be ready to stop if you feel the tractor stop or bog.
/ sub soiler broke top link #3
Could you use a chain in place of the top link? This was mentioned recently (by Ironhog in "lost 4x4), as a method to reduce shock to the top link attachment points when using a brush hog.
It might work in your application too- I can't say from experience, I've never used a subsoiler.
The top link is in compression not tension so the chain would not work. I think I will try to return it and get 1 that has a shear pin in hope of avoiding this again in the future could be a lot worse next time.
/ sub soiler broke top link #5
So did your top link bend? Buckle outwards? I use a subsoiler and it takes a lot of power. I use low gear and high rpms.
Afraid to try it again might break the tractor in teo
Oops I mean two
/ sub soiler broke top link #8
A sub soiler with a built in shear pin is more expensive,of course. I think you can continue to use your economy sub soiler without fear by using a weaker bolt that secures your sub soiler to the top link.
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
2014 FREIGHTLINER CASCADIA 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
master diesel generator (A64553)
master diesel...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
