sub soiler broke top link
   / sub soiler broke top link #1
derek01
I broke the top link while using a subsoiler with my Kioti DK40SEH HST I guess I did something wrong with the 2nd lever that adjusts the float for the 3 pt hitch any suggestions as to what I did wrong and what I should do to avoid this again, I imagine I could have done more damage then I did.
   / sub soiler broke top link #2
I might be wrong, but I don't think the float would help much with a subsoiler. Either way it it catches an imovable object(root,rock/etc) something is going to give & I would rather it be a top link than anything more expensive. I think you will have to run it a little slower & be ready to stop if you feel the tractor stop or bog.
   / sub soiler broke top link #3
Could you use a chain in place of the top link? This was mentioned recently (by Ironhog in "lost 4x4), as a method to reduce shock to the top link attachment points when using a brush hog.
It might work in your application too- I can't say from experience, I've never used a subsoiler.
The top link is in compression not tension so the chain would not work. I think I will try to return it and get 1 that has a shear pin in hope of avoiding this again in the future could be a lot worse next time.
   / sub soiler broke top link #5
So did your top link bend? Buckle outwards? I use a subsoiler and it takes a lot of power. I use low gear and high rpms.
Afraid to try it again might break the tractor in teo
Oops I mean two
   / sub soiler broke top link #8
A sub soiler with a built in shear pin is more expensive,of course. I think you can continue to use your economy sub soiler without fear by using a weaker bolt that secures your sub soiler to the top link.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2008 FORD F-750 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-750...
