Tree plucker/ remover recommendation please
   / Tree plucker/ remover recommendation please #11
For me, I've found the easiest fastest way to be a small back hoe. I chainsaw the tree first and leave enough stump to easily find when I come back with BH. Drag off orcut up the trees. When you dig up the stump with the BH you can pull just the root ball and shake off most of the dirt. 1 wipe over with bucket and you be able to tell a tree was ever there:). It takes a lot more power and tears up much more earth when you push the tree over and try to dig out with the FEL.
   / Tree plucker/ remover recommendation please #12
Bep, Have you considered a "tree getter" ? Easy to build & use. When backing thru a tree with the 3pt hitch version it increases traction as it pulls down on the rear wheels vs. liftihg the rear wheels on the fel version. Either one lifts & rolls the stump away from the tractor which beats the short chain method. Both very effective depending on you tractors capability. MikeD74T
http://www.tractorbynet.com/forums/build-yourself/196716-tree-getter-ver-2-0-a.html
http://www.tractorbynet.com/forums/attachments/12555-tree-getter.html
Mike, I hadn't seen those before - Thanks. I did see jimgerken's (pic below), but I'm very gun shy on pushing with my 3PH now after breaking it a few months ago: http://www.tractorbynet.com/forums/owning-operating/204404-ok-push-trees-over-box.html
attachment.php
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
