Call the Mahindra Police...
   / Call the Mahindra Police... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Someone went and wacked off 8" of my drawbar and drilled a big hole in the end.... And extended the Position Control lever about 6" with a piece of plastic pipe... and look, he did the same thing to one of them thar JD's years ago.... CALL THE MAHINDRA POLICE..!!!!
......and he went and tore into the wiring harness going thru the firewall and put some plastic edging in the hole....and looks like he did the same thing up by the radiator.... Messing with the wiring, too....!!!!
   / Call the Mahindra Police... #3
Um, your drawbar doesn't just slide forward and lock into position there without sawing on it??? My JD will slide up almost flush and lock in that position or stick way out where I can make reasonably sharp turns pulling a wagon. A short drawbar rules that out.
   / Call the Mahindra Police... #4
I don't understand cutting the drawbar ... why did you do that?
It is a two postion drawbar. In the stock 'far forward' position...it is still sticking out too far in the rear. I could have drilled another hole near the center, and made it a three postion drawbar..but then it would be sticking out too far in the front. I do not need a long adjustable drawbar, I do not pull PTO driven implements with my drawbar, only need it to hang a clevis on it to hook chains onto once and awhile. So, my tractor, my decision, wack...... Now I can leave the clevis on the drawbar while using the PTO for three point stuff and nothing hits... [ hey, it made sense to me.... :) ]
   / Call the Mahindra Police... #6
JerryK,
Looks to me that someone should call the MAHINDRA POLICE about the RED paint job on that thar clevis.;)
hugs, Brandi
   / Call the Mahindra Police... #7
JerryK,
I've seen this before. I, myself, am a long term patient.:eek: Tractor insanity.:ashamed: It can get bad.:( The cure is to get more seat time.:thumbsup: Works every time.:D
hugs, Brandi
   / Call the Mahindra Police... #8
Sorry to hear that. Screwed it up pretty bad.
larry
   / Call the Mahindra Police... #9
lol.. thx for the pics
   / Call the Mahindra Police... #10
Makes sense to me too.:thumbsup: I wrecked the PTO shield on my brush hog last year when cresting a steep driveway. The shield rubbed completely through on the drawbar (with no clevis on it). I'm lucky I didn't damage the shaft. That was on my L275. The Kioti drawbar is fine as long as I don't leave the clevis on. I guess I should paint it that brilliant red as a reminder. It's very flashy.
I just painted a couple of tool carriers I recently added to the Kioti (using flat black). But it got me to thinking I should paint some of my tools a bright colour. I often find myself hunting for my green log lifter, or a chain, or shovel, etc., after I carefully set them near tree or shrub where I'm sure it will be easy to find.:eek: I am going to paint the chain hooks and some other tools bright orange.
I also like what you did with the wiring through the firewall.
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
