How much Turbo Boost do you run
/ How much Turbo Boost do you run #1
Jimbrown
Tombstone Az
KIOTI LK30
Made a quick trip to Tucson and back today with my 30ft horse trailer. The trip down is easy as it is all down hill. Coming back on I-10 you have to climb about 3000ft. I was running about 75-80 and pulling 20 to 22 steady PSI on the turbo. The red line is 35. I try to keep under 25 on steady runs. I go higher for short periods on hills or accelerating.
So What do you guys see on steady runs? F250 6.0
/ How much Turbo Boost do you run #2
My truck is bone stock except for the injectors, and straight pipe exhaust. 22 - 23 lbs is all mine will pull period.
Andy
/ How much Turbo Boost do you run #3
The cummins touched 41psi yesterday pulling my Deere up the backroads of pa. Usually 35psi pulls very strongly.:thumbsup:
/ How much Turbo Boost do you run #4
My F350 6.0 will run high 20's to mid 30's steady pulling and gets into the 40's when I really get on it. I do however have larger injectors, a modified turbo and a few other mods going.
/ How much Turbo Boost do you run #5
Both my Ford 6.0's do mid to upper 30's.
Guy across the street has a Cummins pulling truck. 85 psi of boost.
Rule of thumb is each psi equals about 10 hp to the ground at the rear wheels.
Chris
/ How much Turbo Boost do you run #6
my 02 dmax mostly stock just intake, exhaust and boost stick and I max at 22. Wouldnt want to go much more than that as EGT creeps up.
/ How much Turbo Boost do you run #7
Chris
85 psi would split my stock intercooler for sure....49 psi was the highest I have seen.
/ How much Turbo Boost do you run #8
Do these trucks not have a wastegate attached? How do they stop over-pressure, or boost?
/ How much Turbo Boost do you run #9
I do not believe my 06 F250 had a wastegate, but I would only see between 22-30 psi pulling a load. I do have a light foot as diesel was $4 a gallon at the time and as we all know, farming doesn't pay!
/ How much Turbo Boost do you run #10
I don't blame you there, I have developed a light foot too. Partially due to the local populace Running Red light signals..First one thru getts T-boned?Now we have three photo-controlled ticket writing lights in our small Burg of a town. They needed money, and drivers really needed relief from" blasting lights""?The other part was my ole 83 was not turboed- and it did not do any good to pump the soot at the lights..Ha.
/ How much Turbo Boost do you run #11
6.0 has a variable vane turbo. Its motor is actually a International VT-365.
Chris
/ How much Turbo Boost do you run #12
Chris
That is correct. Thanks Chris, could not remember the name for anything. The one bad thing about that turbo that I recall was more frequent oil changes and the recommended use of synthetic. Dirty oil killed it quick, same with carbon.
/ How much Turbo Boost do you run #13
Never had a drop of syn in both mine. Change the oil ever 5K with Dello 400 or Mobil Delvac. Not a single wrench on either my 04 or 06.
Chris
/ How much Turbo Boost do you run #14
Chris
You change your oil every 5k hence avoiding the extended change (7500+) interval. Oil changes at 5k in any diesel is early, but you are only doing the motor good by doing this. Not knocking you at all. I found when I switched over to synthetic in my 06 it cranked easier, warmed up faster and fuel economy increased slightly. I changed it every 7500.
/ How much Turbo Boost do you run #15
I'm more curious about towing horses at 80mph...? I've hauled horses before; I do not like to go that fast with a live load.
When we took the 5th wheel to Texas two years ago, I could easily run those speeds. However, with this Cummins and 4:10 gears, I found my fuel mileage dropped off considerably above 63mph.
Nice thing about Az, NM, and Tx, was the major highways were in soooooooo much nicer shape than Calif highways...
/ How much Turbo Boost do you run #16
How much boost do I run?
Well my 03 6.0 doesn't have a guage so I'm going to answer... All of it.
/ How much Turbo Boost do you run #17
I have thought about it but the simple fact is these trucks never leave with less then 12,000# behind them. That is towing light. Most of the time they have 16,000# or more on them. I would say I am not the norm with well over 90% of my miles towing. I would rather change it more often. Funny thing is I run Full Synthetic in my other stuff like my Nissan Titan. It tows 7,000# to 9,600# 50% of its miles so I split the difference between the normal change interval and the extended change interval.
Chris
/ How much Turbo Boost do you run #19
RickB said:
Manual for a 2001 7.3 PSD specifies a 4000 mile drain interval.
Wow did not know that. I stand corrected. Do you change it every 4k or longer? I thought diesel oil intervals were 7500.
/ How much Turbo Boost do you run #20
The three 7.3L PSD's in the fleet at work all get New Holland 15W40 no less often than every 4500 miles with a 4000 mile target. Total mileage on the 3 is over 400,000 without engine problems.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Bestway 750 Sprayer (A66285)
Bestway 750...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
Steel Coils (A65640)
(4) Hydraulic Cylinders (A65640)
(4) Hydraulic...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
