Rotary cutting pics
/ Rotary cutting pics #1
rattletrap
U.P. Michigan
New Holland T2310
Hello everyone!
I just figured I'd share some mowing pics with you all. This is a piece I own that has been growing in for about 10 years or so. I like seeing pics of this kind of activity so feel free to post your pics, and I will have more to add as things progress.
/ Rotary cutting pics #2
Looks like some slow-going there. I find mowing the pasture to be the most enjoyable of my tractor experiences. Glad I don't have any trees to cut though....
I also enjoy seeing pictures of other's mowing jobs. Thanks for posting.
/ Rotary cutting pics #3
Very nice, rattletrap! Looks like my pastures when I first got the farm. What cutter do you have?
Joe
/ Rotary cutting pics #4
Here are some new and some repeats.
Yeah, mowing tag alders is tedious work. You have to crawl through them slow and easy. I was whacking through a real thick section that had mostly .5"-1" stems. If you get in a hurry there's alot of snipes left standing and I don't intend on driving through my pass again till next year... way too much tire bait sticking up for my liking. Things went very well till I started gnawing on a clump of 2" stuff. I was doing ok and creeping along making plenty of noise and mulch and then the tail-wheel found a hole. Shear-bolt did it's job at least lol
I wouldn't have done it with a gear drive tractor, or at least not very easily. With the hydro I can creep along so slow that the motor doesn't even labor, other than a 1 second snort once in a while when a clump gets sucked in.
I am cutting with an old I.M.C.O. 5' brush hog. If I'm just mowing tall grass I can't tell it's behind me. I'm saving up some money for a 6' hog with slip-clutch and stump-jumper.
Keep them pics coming! :)
/ Rotary cutting pics #6
Nice pics. I love cutting that thick stuff, gives one a sense of accomplishment!
I know the feeling. You can look at the area after you're done and get a smile on your face, knowing you've made a visible improvement.
I also lose track of time easily when whacking brush.... I'll figure on cutting for an hour or so and end up cutting for 3 or 4!
/ Rotary cutting pics #8
These are some pics of somebody's place I mowed last year, it sure grows fast
It really should be cut more often but they pay by the hour so I cut when they call.
I cut a path backing in so I could get a good pic,I have cut it twice before so I know there are no obstacles in the way, but I always cut with the bucket close to the ground, just in case
/ Rotary cutting pics #9
That's a great couple of pics. I like how they are both from the same spot. Easy to see the difference. Nice work!
/ Rotary cutting pics #10
Nothing like fresh mowed grass......pretty. Wish we had something to mow....just brown & dusty.
Charlie
/ Rotary cutting pics #11
Before you take the plunge on the slip-clutch there are a few threads here about the reliability of them, it makes for interesting reading. I have a Land Pride 5 footer with a slip clutch, I wish now I'd saved some money and got the model with the shear bolt.
Nice pics! I like spending a day in the seat mowing, we have a couple fields of our own that get done a few times a year, and a couple of big ones that belong to a friend that we do as well.
Sean
/ Rotary cutting pics #12
Nice pictures, I actually kind of like to mow the tall stuff. A lowered bucket has saved my tractors many times and the FEL has gotten me out of a few washouts too.
/ Rotary cutting pics #13
I've mowed and cut some brush, and trees back through the woods, but the only time I stopped to make a picture was just mowing my pasture with the B2710 Kubota and a Howse 500 rotary cutter.
/ Rotary cutting pics #14
I've posted these before, but since you're asking for photos, I'll show these again. Reclaiming old pastures and hay fields from the willows and poplars.
Joe
/ Rotary cutting pics #15
I have some pics of a effluent pond I mowed the sides are steeper than they look or at least they seemed that way while I was on the tractor mowing
It was actually a " double" pond, one side is active and the other side has a chance to dry out and be maintained, you can tell the active side from the green scummy water, I stayed away from it the best I could but the tractor got a good clean-up after that one
I have really enjoyed everyones pics, I love to mow for cash
/ Rotary cutting pics #16
I've also posted some of these before,but here's some of mine.
Boone
L3400DT/SQ172
/ Rotary cutting pics #18
I second that which Redbug said...a few cows'll keep all that fine munching ground in check! I can only wish I had something as large to maintain//play in! great pics guys.. Thanks.
/ Rotary cutting pics #19
Here are before/after pics (almost from the same angle) of part of a 2.5a lot that I cut twice a year for a neighbor. He's a disable Nam vet so I don't charge him very much to do it. Heck, I would just about pay him to let me cut it for the seat time!!
/ Rotary cutting pics #20
My neighbor asked me to bush hog his overgrown field (once a hay field) next to mine. I just got the bush hog in April and am still learning about it. It has already hit a rock the size of a softball out the back 3-4' in the air at a good clip. The horses had been in the lower part of the pasture (I was in the upper) but took off for the barn when it came out with all of the noise.
I am using an older 5' International Agitech tow along bush hog. (hitches to the drawbar and two wheels trailing. I set the front lower than the back. I usually run along with the bucket on my TC30 maybe 10" above the ground. I go right over saplings, thorn bushes, apple trees, dogwood, birch, spruce, white pine up to 2 inches or so, 3" sometimes. There's noise, wood slivers- sometimes the root ball and bit of trunk. I travel at mid range 2nd at about 1800 rpms. 3rd is too fast, 1st too slow.
One patch of birch was awfully noisy and almost stalled the tractor- clutched it in time. I thought - that's the last time I hit a birch, but on my swing by again- I saw I had run over a pile of rocks and the birch had simply grown in the middle of them.
I enjoy it and it preserves the fields. Everything else up here goes to trees in no time.
I keep our pasture low for my wife to ride on, and slowly the weeds are being replaced by grasses.
2019 Dodge Grand Caravan Van (A61574)
2019 Dodge Grand...
2004 Quincy QSI500WNM31SC Air Compressor (A61572)
2004 Quincy...
2020 John Deere 6120M (A62180)
2020 John Deere...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
