Kubota RTV 500
/ Kubota RTV 500 #21
My tractor is the same way, but in low gear, it's so slow it won't bog down, heck, I could but it up against a tree and all 4 wheels will keep on spinnin', but in high, goin' up steep grades it does the same thing as your rtv. Guess I don't mind too much 'cause it's a tractor:D. I guess if it was an rtv, it would bother me some. Was 900 or 1100 a lot more expensive, and are the any less prone to this issue because of the extra power?
Well I have a BX23. I can run that up the same hills with the BH,FEL and MMM attached in high range and never have to pedal it. Even with a load in the FEL.
It's a design flaw in the 500 that Kubota won't own up to.
SHMBO gave me the green light on an RTV1100. I called a couple of dealers to discuss, but the locals probably figured out who I am due to my username on TBN and haven't called me. Note to others: use a name that isn't too obvious.
Anyhoo..I'd like to buy an 1100 for the diesel, heat, cab etc..but i'm very hesitant given the response to my concerns by the dealer and Kubota. let's face it, if I drop 18 large on that machine and run into the same issues I REALLY won't be happy....Sad, because I like what I see on the 1100. Especially since I have to spend hours in bad weather plowing the neighbors driveways and the rightaway leading to my house.
Another plus to the 1100 would be taking my daughter out for rides in the winter.
Again, blaming the owners is not good corporate or dealer policy..See Toyota lately?...Different and more serious, but the same behavior, general arrogance.
/ Kubota RTV 500 #22
I agree the HST pedal is not intutitive. You normally want to press it down farther to go up a steep hill, but that is the wrong thing to do. My BX in high range with a load will not pull a hill easily loaded down. I have to back off the pedal and slow it down or it bogs down. Usually I just use low range.
I'm ignorant of the RTV's. Are they like a tractor where you have a hand throttle and the pedal controls the HST?
/ Kubota RTV 500
All good posts.
Please consider the following:
-Unit is fuel injected; not carburated.
-Unit has lost performance; would easily climb hills in high that it now has trouble with in low.
-The Dealer did my 50 hour service;. not sure what that means as I trust my work much farther than any Dealer period
-Poor fuel quality has never been an issue
Now hear this:
Got a call from Kubota Technical Service today, and they have agreed to have my Dealer perform a hydrostat adjustment along with an RPM adjustment.
The representative tried to be very evasive and tell me these RTV are preset at the factory for level ground -not hills and mountains. When pressed for what type adjustments he beat-around-the-bush and tried to get me to believe an "....altitude adjustment..." That did not go far.
He also said..."One should not believe what is written on these discussion forums". I reminded him that one could not believe what Kubota Dealers are exposing as not a problem, but rather an Operator problem.
We will see what happens. Waiting on a call from my Dealer.
/ Kubota RTV 500 #24
Hopefully the adjustment will solve your problem. I'll be surprised if it's a hydrostat issue - it just doesn't seem very consistent with the flat versus uphill conditions that you described.
By the way, did you start having problems AFTER the 50 hour dealer service?:confused:
Good luck!
/ Kubota RTV 500
Do not be surprised that it is a hydrostat issue, but not the entire problem.
Unit started experiencing loss-of-power 8-10 operating hours ago. Around the 40 hour mark. Just had the 50 hour service done last week
/ Kubota RTV 500 #26
All good posts.
Now hear this:
Finally..Kubota U.S. is starting to own up...What about the rest of us Kubota?
/ Kubota RTV 500 #27
The RTV only has a gas pedal...Wish it did have a hand throttle, might help.
/ Kubota RTV 500 #28
This message is for robinbr about the Kubota RTV 500. I bought my Kubota RTV 500 in Dec. 2010 and I am having the same problems. Brought it to the dealer and got the same answer about it being the operator's fault. It loses power unexpectedly and trying to climb a low incline is sometimes impossible. I live in Louisiana and we don't have hills or snow. Did you ever resolve the problem? I am about to sell this thing and get anything but a Kubota. I'd apreciate your help in this matter.
/ Kubota RTV 500 #29
Well... That just made me change my mind on buying a Kubota RTV.... I was thinking about buying one this fall but now I will be reviewing other RTV's.
/ Kubota RTV 500 #30
It is obvious that Kubota customers do not understand HST transmissions. First off, with an HST you can either have speed or torque, you can not maximize both at the same time. Secondly, and HST is a fluid drive transmission, it can not "down shift" when it wants to, there is no such thing. The whole issues here is that on an RTV type vehicle with an HST, you can not simply step all the way down on the peddle to get full torque, it is the way it works. If you are not used to it, or it is differant that other companies units, that does not make it wrong, just differant. Get used to it or buy a belt drive unit.
As for the adjustments, there are several adjustments that a dealer can do to impove performance of the RTV500. These are set up "on the bench" at the factory, meaning that they do not drive each unit and adjust it, they use a gig of some sort. I have seen many customer claim that their machine never ran as good as it did after it had the adjustments done to it. Just FYI.
/ Kubota RTV 500 #31
Reading this thread is getting me fired up from my own fun with the Kubota "engineers." They are really good at coming up with reasons its not a design flaw. Excuse number 4 from them on my HST failure was I used it in a cold location (Upstate NY). Its like our politicians lately, come up with endless random distractions from the problem and hope one sticks.
As for the poster mentioning the "bombproof HST's" I think a few posters here have low hour smoked ones they'd be happy to sell you. On the other hand my neighbor's "failure prone" belt drive polaris 500 has now towed back my Kubota for the second time.
/ Kubota RTV 500 #32
Secondly, and HST is a fluid drive transmission, it can not "down shift" when it wants to, there is no such thing. The whole issues here is that on an RTV type vehicle with an HST, you can not simply step all the way down on the peddle to get full torque, it is the way it works..
The RTV hydrostatic transmission is different from the hydrostatic transmission used in a tractor. The RTV transmission has loading sensing and automatically varies the transmission ratio. There is no direct connection to the swash plate in transmission as there typically is with CUT tractors. The foot peddle controls both the engine throttle and a servo in the transmission. The servo controls the swash plate on the transmission pump and will vary the pump displacement depending on the load on the transmission. There are two motors in the transmission. One with fixed displacement and one with a variable swash plate that is load sensing. Do a search in the ATVs & Utility Vehicles forum on the RTV500. There are threads that discuss adjustment of the servo and throttle cables. Proper adjustment is critical for optimum performance and seems that many RTV500s are shipped with the servo misadjusted.
/ Kubota RTV 500 #33
Matt, don't sell the 500 short. Seems that the new owneers of the 500 are quite happy with it's performance. Seems that Kubota made the servo and max RPM adjustments that thoe of us that bought the first ones had to do. It does make a huge difference.
They won't climb a pine tree in high range, but generally they are fine. low range is unstoppable. These are work machines with some play ability.
/ Kubota RTV 500 #34
Stonehauler:
Your discription is "spot on" as to the design of the RTV transaxle (I have atttended several training sessions on this unit). However, even with the variable assist motor (VAM), you still must choose between speed or torque, there is not "shifting" in the transmission. As the load is increased, the angle of the VAM swash plate is changed, thus engaging the VAM, this will decrease the speed (same amount of fluid is now being used by 2 motor, not 1). The whole point of my post was the with an HST (of any type) you can not push all the way down on the pedal and expect to reach the peak torque of the HST. On the RTV500, it is critical that all the adjustments are correct. Your local Kubota dealer has access to on-line information from Kubota detailing these adjustments. Sorry if I was unclear, I was also in a foul mood when I wrote that post (had been listening to customer complain all day) and was most likely a little harsh in my wording. Sorry, I am human.
/ Kubota RTV 500 #35
By the way, the HST is what is refered to as a "servo control" (no mechanical link from the foot pedal to the pump swash plate). This is very common on utility tractors of higher hp. This type of control system is what you will find on L30 and L40 series tractors, althought the transmissions themselves are different that the RTVs.
/ Kubota RTV 500 #36
Thanks for the replies and clarifications. I did not realize you were a dealer.
As far as the 'servo control' on tractors, is not their main purpose for peddle effort? Generally on a tractor the ratio is based on peddle position and does not vary with load as with the RTV.
/ Kubota RTV 500 #37
Yes, genrally the servo is used on transmissions with higher volume and/or higher pressures. When you get into the larger transmissions, the average person can not press the pedal down on a non-servo unit, especially under a heavy load. All the pressure in the transmission is not only acting on the motors (axles, tires, etc.) but also on the pump swash plate. The servo allows the operator to move (and hold) the swash plate by simply operating a valve and letting charge pressure (generally) do all the work. In the RTV series, the transmission is small enough that it does not need a servo the be operated, but it was designed with on for convience. With a servo, the designers also have much more flexibility in transmission placement. On non-servo units, you pretty much have to have a direct link from the foot pedal to the HST swash plate (usually no cables, they tend to strech under such load). Imagine the adjustment nightmare it would be to adjust an RTV if there were rods and cams from the foot pedal to the HST in the rear! Again, sorry if I was snappy on the first post.
/ Kubota RTV 500 #38
I read your post again and may have mis-understood you the first time a little. The fact that the HST is servo control does not affect the general operating charactoristic (power, speed, etc.) of an HST. It is just another way to control the operation of the pump swash plate.
/ Kubota RTV 500 #39
I am having the same problem with an RTV500. The engine turns up seeming fine in neutral, but in gear it doesn't reach full speed in either high or low gear. It also dogs on hills and almost stops on hills it has previously walked right up. I have changed the plugs not 10 hours ago, gapped properly. The fuel was treated.
Good info previously on the servo control on the HST. Did not understand that previously.
/ Kubota RTV 500 #40
hi all! had my rtv500 for a couple of months now. think I've read all the post on this machine. I have the same issues as everyone else. low power, no ability to pull hills at all. it just seems the little motor isn't putting it's heart into it. have tried the servo adj and throttle adj. tried adjusting spring tension on the governor. seemed to help, but in my experience with golf carts, this is not the answer. something I'm overlooking?
New/Unused Pallet of Chains, Binders, and Chain Slings (A65583)
New/Unused Pallet...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2021 PC210L Komatsu Hydraulic Excavator (A64553)
2021 PC210L...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
