tractor/ wood shed
/ tractor/ wood shed #1
displacedPA
Gold Member
SC
NH T2310
While waiting on my B2320 I decided to build a 16x16 lean two off the back of my current shed. The plans are to store one cord of fire wood under the 4 foot overhang. Then the tractor and implements under the remainder. The post are set now going to pick up the lumber and sheeting... here is a pic of the posts.
/ tractor/ wood shed #2
says the photo is corrupt. :confused:
think I fixed the pictures here ya go... this is last weekend working on the posts. I will bring the area up to grade once the shed is built
/ tractor/ wood shed #4
Since you are in the early days of construction, thought I would share this. I had a lean to shed, which I planned to store my tractor in, but in the end I put up doors to enclose it. I did this for several reasons, kept the squirrels out (they eat the wiring on my neighbors 60 dollar tractor), keep out some of the mice, we get heavy fogs and the tractor would be all wet in the morning and since me and about 50,000 other people have a key to my tractor at least now there is a lock on the door.
I used T1-11, because that was already on the other 3 sides. If I had no shed I would have used metal at least here there is a place that will cut the metal sheets to length. Hopefully, the place you are getting the sheeting from do as well.
Keep the pictures coming.
That is good advice, more than likely when funds allow I will add sides..
my Father is recomending the same thing... In the mean time The new bota will at least be out of the rain and hail storms we seem to get around here.
/ tractor/ wood shed #6
Just a quick note, The corded wood will draw in mice and pack rats
Wayne:mad:
T1-11 will match the rest of the shed so looks like thats the route I will be taking.. It might sit with no sides until fall..
/ tractor/ wood shed #8
Feel free to say you know this already.
On the thinner T1-11, I suggest you only space your 2X4s 1 foot apart, this will avoid them wrapping. On the thicker T1-11 you can get away with 2 foot apart. Make sure water cannot get in above or below as they will start to come apart. Paint the inside as well as the outside. This will help keep moisture from getting inside in. If you or your dad was in the military, Lowes gives 10% off. Need a military id or DD-214. At least by me the thinner T1-11 is almost $24 a sheet.
/ tractor/ wood shed #10
Thanks you for the post.
__________________
here is what we got done last evening... note some of the boards are just supports to hold everything square while we are building it. the hard part is done now. have to add the rest of the intermidiate boards, then sheet it and figure out what kind of roofing material I should use. any thoughts??
/ tractor/ wood shed #12
I was going to encourage you to keep the sides open for awhile and test it. I did an 18x12 enclosed. But with my tractor I note that I have to move 627 items to get to the thing in the back. So I just added another 18x12 lean-to and kept it open so I can have access to all the attachments without moving everything.
Ok so this maybe a deticated tractor shed... the side will be left open for the time being..
dealer emailed me this am saying the tractor is ready for delivery. tractor is coming from barlows so Im thinking next week some time. cant wait to see it in its new shed :D
/ tractor/ wood shed #15
If you or your dad was in the military, Lowes gives 10% off. Need a military id or DD-214. .
Unless the policy has changed the Military discount is done once or twice a year unless the veteran is disabled with VA ID then the 10% discount is every day.
I'd use metal roofing which is what I use on storage building. One you don't have to sheath with wood and the frame cane be on 48" (2x6's)centers with 24" (2x4) cross braces. Use one opaque sheet on the roof and the inside will be light when you close in sides which some times leads to closing in ends.:)
Metal will be a little higher but when you figure in speed of completion, lifting sheathing and shingles and less wood for sheathing. Call a metal roofing supplier and price it. Building Supply stores may also sell it as well as farm supply stores.
Use gloves. 2x6 ridge down to side 4' on center. 2x4s across 2x6s 2' on center is what I do on my buildings as in this picture.
that is a very nice pole building JT.
I went with a product called Ondura its a coragated product that is aprox 1/8
I almost went the metal route..
Brady emailed me this am about delivery he must be out of town when I emailed him back I got an out of office reply. I will have to call steve to set things up.. They said the tractor was ready for delivery I can hardly wait to see it.. and get some seat time..
/ tractor/ wood shed #17
I used Ondura on a small porch one time and it's fine also. Don't drop it on it's corners:) it'll break the corner off. My brother in law used it on a big deck several years ago and it has held up well, just shouldn't walk on it like metal but most people don't walk on their roofs.:)
I've waited on Barlow deliveries before but they're only 2 miles from this building and 7 miles from my house.:)
/ tractor/ wood shed #18
Just got back from the Lowes by me and got a 10% military discount! Sales slip is included, note date at bottom and discount type at top!
On the roof, I suggest going with a metal roof. Call around and you should be able to find a place that will cut them to the length you need. On the boards 12 inches from top and bottom, then space 24 inches in between. Do NOT screw them down that you bend the metal.
/ tractor/ wood shed #20
Lowe痴 Expands Support of the Military with Year-Round Discount
10 Percent Discount for Active, Reserve, Retired and Disabled Military Personnel and Immediate Family Members
February 10, 2010 09:41 AM Eastern Daylight Time
MOORESVILLE, N.C.--(EON: Enhanced Online News)--Lowe痴 Companies, Inc. announced today it will expand its support of the military by offering an all day, every day 10 percent discount to all military personnel who are active, reserve, retired or disabled veterans and their family members, with a valid, government-issued military ID card.
展hat a great way to say thank you?/P>​
All other military veterans will receive the discount on the Memorial Day, Fourth of July and Veterans Day weekends.
A discount is good, take advantage of it if you qualify.
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
2019 John Deere 8320R (A64126)
2019 John Deere...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
