The truth about Arched Steel Buildings...
   / The truth about Arched Steel Buildings...
Since this topic just came up on another forum, I guess it is time to update my thread. We have been living in the 500 sq ft living quarters for over 2 and half years. The sprayed on foam insulation has been fantastic. We have a small window unit that usually only gets run in the evenings for a couple of hrs in the heat of the summer. A 1500 watt cube heater is plenty for the winter. I put a old wood stove in the uninsulated shop so I can work comfortably in the winter.
The biggest drawback was the 30x36 shop.....WAY TOO SMALL WHEN FILLED WITH "STUFF". If you are going to build any shop, go bigger, bigger, bigger!
I have zero regrets and would build another in a heartbeat. Once I got ours all dialed in on the apt side, my wife looked at it and said, " Why didn't we just build a bigger one and make it our permanet home? (Hand smacking on forehead).........grrrrrrrrrr! I had no idea she would actually like a "Man Cave":(
Anyway, yes we have started on the log home:http://www.tractorbynet.com/forums/projects/156451-log-house-project-begins.html
I have helped build a 50x80 hay storage quonset nearby. The owner had no clue, poured a crappy trough, bent the first arch like a pretzel. I went over there, loaned him my tractor boom & came up with a way to mod the trough so we could anchor the arches. I also took the bent arch apart and pounded it back into shape. Once we got it up and a few more the rest went up in a week. If you are going to build one, please do some homework and you can keep the blood pressure under 250:D
RD
   / The truth about Arched Steel Buildings... #52
Motor7: I guess you might not have heard of the fire hazard posed by poly insulation when not protected by a fireproof layer ?
This: http://www.foamrun.com/wp-content/uploads/2009/10/foambook_ch5-fire_and_foam.pdf is a very good and honest assessment of the risks involved and you will see quite a few destroyed buildings in there.
The least that is required for an application like yours is a layer of chicken wire followed by sprayed on plaster (what some casll the gunnite process). The geometry of your building makes it very tedious to do it another way.
Be safe
Keith
Keith, yes I am aware of it. I am not going to cover it, just be carefull with any open flame. The interior walls are painted OSB, so not so fire proof either. My log house will be made out of 6x6 cedar...so I guess I will just "live on the edge":cool:
RD
   / The truth about Arched Steel Buildings... #54
If you read the article, they say that with a large surface the foam ignites so fast and burns so hot that you would be extremely lucky to even get out of the building in time. It is not like a wood fire at all, closer to ignition of a liquid fuel with the heat intensified by the insulation properties of the foam. The danger is much higher than with a wood (or paper) structure.
The fires cited were started with either a welder or torch. The shop side of my building is un-insulated where the welder and torch live. The apt side does not have a source of that kind of flame, but thanks for the info.
RD
   / The truth about Arched Steel Buildings... #56
Outside is Done!.....now working on the interior walls for the apt......
RD
So MotorSeven comes from liking Chevy pickups? Is that a '68 and a '69 Chevy sitting in front of the barn?
hugs, Brandi
Brandi, Motor7 was my call sign for the last(and best) 11 years of a 27 year career.
Close....a '68 Short Step(a 'built" 350 kinda hot rod) that is a work in progress{cough} for {cough}8+ years, and a '72 Long bed(250 straight six 3 on the tree). The '72 is my beater go to town run errands truck. It saves me from driving the D-Max and those 6 expensive tires on the ground along with the price of diesel these days:thumbsup: But when it's time for the heavy stuff the D-max rules!
Play:
Lite Work:
   / The truth about Arched Steel Buildings... #59
how did you attach wood to the arches? Are there any lag type bolts through them or just the strap from inside.I have a 30x50 just up with factory back wall but wanted to put a steel 12x12 roll up door in the front and no real info on how to do it right.
Eagle Weathervane (A55853)
Eagle Weathervane...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2018 WESTERN STAR 5700 TANDEM AXLE SLEEPER (A56138)
2018 WESTERN STAR...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
