ECONOMY TRACTER
/ ECONOMY TRACTER #1
AArchy
Economy POWER KING
I am look ing to buy an Economy tractor by power King to restore and use for my home property maintanence. I live in the Baltimore, Maryland area.
/ ECONOMY TRACTER #5
Welcome to TBN, Aarchy. The Economy/Power King tractors were sold in the 1950's, '60's and '70's, I think. You'll most likely find well used ones in need of some TLC, but since they have become collectible, you can also find fully restored ones.
I have seen them for sale at antique farm shows and swap meets and, occasionally, one pops up for sale on Craig's List or in the local classifieds or pennysaver ads around here. Don't know if you'd find many of them directly in the Baltimore area, but if you include the surrounding Maryland, Delaware, Pennsylvania and even Virginia/WV regions in your search, something surely would turn up. There are several currently listed for sale on Ebay, I think.
If you are prepared to invest some time and/or $$$, they can make a very good machine for property maintenance and garden work. They have quite a following and it looks like parts are readily available through Ebay, etc.
Good luck in your search.
/ ECONOMY TRACTER #6
CL has one in Murfreesboro TN for $2K, 14hp 1969 restored. With no other info is that ball park value if in good condition. I see ebay has a ton of parts for them.
/ ECONOMY TRACTER #7
Before you buy anything then fixing up check into parts availability and cost of the parts. Secondly you really need to decide if you are looking for a tractor for doing work or a tractor project to restore that you'll use around the house.
If you're looking for something cheap that you can tinker on but keep costs down then I would try to avoid the tractors that people are restoring. My neighbor picked up a well used yanmar for $1500. It needs some work but not a lot of money (he hasn't done a thing with it yet). Even though it's not pretty and you'll not find many (if any) of them restored once fixed it'll do almost anything you'd ever want to do around a house.
/ ECONOMY TRACTER #8
Good point crazyal.
There was some guy in the UK that restored a David Brown from ground up. He dad had a tractor like it when he was a kid and he really needed a working tractor. He seemed very please he had the tractor that met his needs for much less cash than a new tractor since he did the labor and it was meaningful to him on several levels.
/ ECONOMY TRACTER #9
The old Power king used a Crosley transmission and rear end. Parts are expensive.
I was looking for one myself, but parts are more plentiful for the Farmall Cub.
Either one is expensive to fix up, but unless you are into fabricating your own parts, the Cub may be the way to go.
But if you do find one you like, just remember, the 18 hp Kohler engine was a bad design, and parts are unavailable.
/ ECONOMY TRACTER #10
+1 those thoughts. There seem to be both workhorse and trailer queen Economy PowerKing's out there. I think the OP wanted a fixer to revive and put to work. Dunno if parts prices are getting too pricey. A 1970's or '80's Mitsu or Yannie would be a good alternative... reliable, unglamorous, inexpensive worker.
/ ECONOMY TRACTER #11
Welcome, the Powerking Economy tractor was my first tractor. I still have it. Parts can be hard to find but there is a place here in Texas that has many parts and his prices are reasonable. Mine has the tandem transmission and also the FEL and MMM. Tractor is a hard worker and can move a considerable amount of dirt. Not to say there aren't design flaws but overall a good piece of equipment.
/ ECONOMY TRACTER #12
Hiya,
I have one that I need to move out. 1968 Economy Delux, 12hp, dual transmission, dana 44 differential, ribbed fronts and R1 rears. headlights, generator system, new battery, fires right up, never misses a beat.
Includes:
12" moldboard plow with culter disk
Mid mount cultivator
rear mount cultivator
potato hiller
disk harrow
snow thrower
Rare cord wood saw
mower deck
tire chains
Also included is an Economy wood splitter powered by a real Wisconson engine.
$3500 takes it all
Tom
more info coming soon! (A61569)
more info coming...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
