Loader Id like to paint my loader (decals)??
/ Id like to paint my loader (decals)?? #1
rkboyer911
Member
Grain Valley Mo
JD 855
Id like to paint my model 52 loader but i cannot find replacement decals...any help would be great.....Also will a 70a loader bucket fit on my 52?
/ Id like to paint my loader (decals)?? #2
Just paint it.... even if you can't find the decals. That thing is hideous!!! :laughing::laughing:
/ Id like to paint my loader (decals)?? #3
Get decals from another model that has 52 in it. Like a 5303 tractor and simply cut the extra numbers off. You tractor will look newer!! :thumbsup:
edit: I mean 5203...
/ Id like to paint my loader (decals)?? #4
When I painted my loader I used the blue tape and covered up my decals. The part number is PT13382, you might try to google it.
/ Id like to paint my loader (decals)?? #8
In addition, there are companies out there that make custom decals. Also, Hobby stores have a kit that you can make your own decals with an ink jet printer.
/ Id like to paint my loader (decals)?? #9
I looked on JD parts and it appears JD no longer sells them. If you decide to take them off, try WD-40. If the loader has paint run marks use a single sided razor blade and scrape off the high spots works great, the color changes and you can see how much you are taking it down. Much better then sanding. Also Lowe's sells Rust-Oleum JD green paint, by me it is $4.35 a can. A little light rubbing compound will take paint off the sticks.
https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.publicservlets.HomeUnsigned
I bought some spray cans of it from Home depot to touch up my tractor.....I wasn't sure if it would not be better to buy a HVLP gun and spray it...or do it with the spray cans. Id bet it would take several cans to cover all of it.
/ Id like to paint my loader (decals)?? #11
Air compressor and spray gun would do a better job, but that is not always an option for people. Yes, you would need a number of cans. If the loader is in real bad shape, for sure I would do the spray gun route and prime it first. The spray can route lets you do it in pieces and less clean up time. When I did mine, I took it all apart I did not take off the hydraulic lines, but I did take off the cylinders, granted I could not go too far with them. I painted the bucket, parking stands and cylinders first, which had to dry as I need this to get the loader off the tractor. I removed the masts, cleaned the grease off and painted them and the rest of the loader.
Couple things, make sure you cover everything up, there is more over spray then you think. I could not hold the mast up and get the pin in. After a few choice words, I came up with the idea to use a dowel rod to put it together, than put the pin in and slid out the dowel rod out.
/ Id like to paint my loader (decals)?? #12
rkboyer911 I am surprised you haven't found any replacement decal sets. For Cub Cadets there are all sorts of "old" replacement decals that people make for restoration work.
JD5210 have you tried the Rust-Oleum JD green spary paint?
I was wondering how well the color matched.
/ Id like to paint my loader (decals)?? #13
I have used the Rust-Oleum JD green paint and I think it is a good match. What I painted, I painted the whole item and did not try to spot painting anything. I have tired Rust-Oleum, paint from JD and BP of the 3 Rust-Oleum seems to be the easiest to paint and go down. My neighbors dad is an ex-JD dealer, he thinks the paint is a good match. He uses the paint from JD, he says it holds up to the sun better, but since I keep the tractor inside and JD paint is almost twice the price I no longer use it.
I have not painted any of the fiberglass parts (hood, fenders). My concern here is how these paints hold up on parts that flex ie will I get paint cracks.
/ Id like to paint my loader (decals)?? #14
Two of the local Farm and Home stores around me carry Van Sickle brand implement paints in a wide variety of colors. I've used it in the past with decent results, but it does suffer from UV exposure and eventually turns chalky with oxidation. I have only used it straight out of the can so far. The next time I use it, I'm going to buy the hardner for it. It is supposed to make the overall result glossier, more chemical resistant, more UV resistant and also make it harder to chip/scratch. Of course, you do have to use the proper respirator equipment when spraying paint with an isocyanate hardner.
/ Id like to paint my loader (decals)?? #15
Back on the original topic of decals.... just because JD Parts shows that they are no longer available doesn't mean that they aren't out there. It just means that wharehouse no longer has any and won't be getting anymore. Go to your local JD with decal set part number and ask them to search the dealer network. There could be a set somewhere setting on a dealers shelf that your dealer could arrange to "buy" and then resell to you.
I had to get a hinge rod for my 955 this way a few months ago. I got lucky and somebody did have one setting on their shelf.
/ Id like to paint my loader (decals)?? #16
:laughing: :laughing:Write to john deere and tell them your going to use a Kubota or kioti decal.......they will find you the parts LOL:laughing: :laughing: :laughing: :laughing:
/ Id like to paint my loader (decals)?? #17
You might try a local sign company. I asked about getting Junk Deere decals for my 2520. They said no problem.
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
Gas-powered Electric Start Air Compressor (A66408)
Gas-powered...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
Morooka MST 2200V Tracked Truck (A62679)
Morooka MST 2200V...
