Loader Id like to paint my loader (decals)??
   / Id like to paint my loader (decals)?? #1
rkboyer911
Grain Valley Mo
JD 855
Id like to paint my model 52 loader but i cannot find replacement decals...any help would be great.....Also will a 70a loader bucket fit on my 52?
   / Id like to paint my loader (decals)?? #2
Just paint it.... even if you can't find the decals. That thing is hideous!!! :laughing::laughing:
   / Id like to paint my loader (decals)?? #3
Get decals from another model that has 52 in it. Like a 5303 tractor and simply cut the extra numbers off. You tractor will look newer!! :thumbsup:
edit: I mean 5203...
   / Id like to paint my loader (decals)?? #4
When I painted my loader I used the blue tape and covered up my decals. The part number is PT13382, you might try to google it.
Ill try that or the tape trick thanks
   / Id like to paint my loader (decals)?? #8
In addition, there are companies out there that make custom decals. Also, Hobby stores have a kit that you can make your own decals with an ink jet printer.
   / Id like to paint my loader (decals)?? #9
I looked on JD parts and it appears JD no longer sells them. If you decide to take them off, try WD-40. If the loader has paint run marks use a single sided razor blade and scrape off the high spots works great, the color changes and you can see how much you are taking it down. Much better then sanding. Also Lowe's sells Rust-Oleum JD green paint, by me it is $4.35 a can. A little light rubbing compound will take paint off the sticks.
https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.publicservlets.HomeUnsigned
I bought some spray cans of it from Home depot to touch up my tractor.....I wasn't sure if it would not be better to buy a HVLP gun and spray it...or do it with the spray cans. Id bet it would take several cans to cover all of it.
Brown 6' Disc Harrow (A50123)
Brown 6' Disc...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2020 FREIGHTLINER...
