Backhoe Backhoe leakdown
/ Backhoe leakdown #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
OK I am the new owner of a BX25 and now have about 8 hours on it. I was wondering if it is normal for the backhoe to sag down to the ground from its fully retracted position over the period of a couple days?
I could see it on an older model, but would think a new "tight" unit would hold position. I just stuck the lock pin in to keep it in place.
Ryan
/ Backhoe leakdown #2
I have a CCY SC2450 and mine will drop some during use and while sitting but not to the ground.
Mfg say it is normal but I am with you on new vs old.
I run with lock pins in place unless I plan on using the BH.
/ Backhoe leakdown #3
My BX will drop overnight if I don't use the lock pin.
I was told by Dealer that is typical and from what I understand from other owners common.
/ Backhoe leakdown #4
Normal..My BX will do that without the lock pin installed...Throw it in and forget about it.
/ Backhoe leakdown #6
yup, sounds normal to me. Mine will leak down pretty quickly without the pin in place.
Matt.
/ Backhoe leakdown #7
Unless you plug in the lock pin it will
always do this as the simple force of
gravity it taking its toll on the boom.
/ Backhoe leakdown
Thanks for the reply's.....just wanted to make sure I didn't have a warranty issue for the dealer.
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
19 gal Portable Sandblasting Cabinet (A66408)
19 gal Portable...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
