Toothbar
/ Toothbar #1
sjohnson79
Member
Oxford, OH
2008 John Deere 2520
Was wondering if anyone has added a toothbar to their FEL. I did some research and look like I could get one for around $150.
Is it a useful attachment? Easier to dig? Anything you can comment on would be helpful. Thank you.
/ Toothbar #2
I bought a used one for $100. Heavy duty. I didn't like it at first... it would leave "tooth marks" in the ground when I wanted a smooth cut. I didn't have really hard ground so it really wasn't need for digging. When I put my grapple on... THAT's when I fell in love with the tooth bar. I can put it on and take it off in a few minutes.
Where can you buy one for $150???
/ Toothbar #3
I just put a toothbar on my new Mahindra 3016 today. I bought one on ebay and received it in 4 days. I paid about $350 for mine though.
I haven't had time to really try it out, but I did play a little until the rains came. I was surprised at how easy it cuts into the soil. I am no expert, as this is my first tractor and I only have about 10 hours on it, but the toothbar seems to make a real difference.
/ Toothbar #4
It will help on moving dirt as the teeth digs in. And depending on the size of your bucket... prices are on the $350 the last time I looked for one. I ended up buying individual tooth and should have done it a long time ago. Prices is under $100 for 8 pieces and grade 8 bolts. I installed it on my 68" bucket. I do a lot of dirt moving and it helps a lot. I am clearing my backyard and all I am using right now is the fel with teeth and box blade. See the pic of the teeth I installed....
/ Toothbar
I found this manufacturer, it asks for you zip code so prices may vary. The 47" was $166 for me, I assume that's the size ill need since I have a 49" bucket (I think).
Looks like you pre-drill holes in the side of your bucket and it will bolt inside. Might have to shim it little to get it to fit... a light duty model but its all ill need.
The mini:
Berlon: Mini Tooth Bar
Other tooth bars they have... maybe better? More $ though.
Berlon: Bolt on Tooth Bar Over Bolt on Cutting Edge
/ Toothbar #6
I installed a toothbar and it really makes a difference in how well you can dig in. I purchased mine from Iowa Farm Implement on E bay and it has been very durable.
/ Toothbar #7
Looks like you pre-drill holes in the side of your bucket and it will bolt inside. Might have to shim it little to get it to fit... a light duty model but its all ill need. The mini: Berlon: Mini Tooth Bar
That's the one I was close to buying before finding a used one. It doesn't have 1" shanks like the rest of them but that saves in weight. You want to get the 49" version (which will be 1/4 +/- inches shorter). If you get it, please let us know how it turns out. Anyone else with one of these???
/ Toothbar #8
Check Ratchet Rake, LLC - Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, New Holland, Bobcat, Fire safety, they are made in Carlisle, PA, cost about $300., sold at Tractor Supply stores. I bought one and couldn't be happier with it. Off and on in about one minute, heavy cable and heavy ratchet strap holds it securely in place. I use mine to remove brush and undergrowth, grade driveway and prep ground for sowing. Check the video on their website. Well worth the money.
/ Toothbar #9
I have one, and it's currently off the bucket as I don't need to dig holes or get into compacted piles of stuff.
On the plus side, they make digging easier. On the minus side you need to remove it to use the FEL bucket for fine grading, or getting down to grade to get the last bit of rocks or whatever.
/ Toothbar #10
I believe it was 3RRL that came up with the idea to drill the bar hole (in the side of the bucket) to fit at the teeth end of the slot or elongated hole, then if you do not need the toothbar simply loosen the bolts, pull foward, and flip the bar inside the bucket. This is the way I mounted mine, never flipped it other than upon installation to make sure it would work. If you have single hole mount this info is useless, if you have the long slot you have a choice.
/ Toothbar #11
I bought one via E-bay...Iowa Farm Equipment. I am happy with it so far.
It appears that the "Mini" one you are looking at by Berlon does not have replaceable teeth...is that an issue?
/ Toothbar #12
I do that with my Markham from time to time. It can make fine pouring of pea gravel and other fine stuff more controlled; but it can also limit how much material you scoop up in one trip too. You should here the noise it makes when the bolts loosen enough for gravity to take over and it swings back down on the bucket's edge.
/ Toothbar #13
I added a Markham toothbar to my FEL soon after I bought the tractor. Makes all the difference when digging, scooping. I had a big load of rip-rap to move to my sea wall and the tooth bar make that an easier job. Agreed it would be nice to have the smooth edge of the bucket every now and then, but the box blade and the bucket heel in float mode work fine for smoothing.
It is a GREAT addition.
/ Toothbar #14
I bought mine to help grab roots and brush that would otherwise resist the lip of the bucket. It also works well as a miniature fork of sorts. For example, I have some eight foot wide wooden benches that I can scoop underneath and easily reposition (across the property) with the FEL. And I can still backdrag an area smooth simply by angling the bucket up a bit.
A bolt on each side of the bucket keeps it attached. I removed it last winter and briefly replaced with a length of pvc so I could push some snow. No problems. I think it was around $140. Not sure who makes it though.
/ Toothbar #15
Years ago, being cheap, I bought some hardened (German-made, surprisingly) combine teeth, some steel bar, and welded up a tooth bar for my 48" bucket. Very useful for those things that toothbars are good for, like ripping up brush, loosening soil, etc. I posted photos back then, maybe someone will find them interesting again? The only thing I'd change is moving the fastening bolts to the ends.
/ Toothbar #16
Does anyone have pictures of how the holes are supposed to look or the link to the original thread?
/ Toothbar #17
Sideways, go to the Attachments Forum and search "My turn to share attachments". This will show you how to drill the holes. If your toothbar has the long slot hole and you want the ability to tuck it in the bucket remember to drill the holes closer to the teeth.
/ Toothbar #18
Those look like rock guards from a sickle bar mower!
/ Toothbar #19
First thing to consider is the fact that you have a loader on your tractor...not an excavator.
That said, the addition of a toothbar (as well as adequate ballast on the 3PH) wll really improve your tractor's ability to dig in to a pile of dried out, clumpy dirt or mulch. Without the toothbar, you may just set there spinning your tires (as I did before I got my toothbar...but that ballast I mentioned really made it work).
I've had my toothbar just over 10 years now. When I went from a 54" bucket (on my first tractor) to a 61" bucket (on my 2nd tractor), I just modified the toothbar to fit. Still using it on my 3rd tractor (which also has a 61" bucket).
All said, the toothbar is a very handy and relatively inexpensive addition to your loader.
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
4022CFL (A59228)
4022CFL (A59228)
2016 INTERNATIONAL LF687 T/A 6X2 SLEEPER TRUCK TRACTOR (A59908)
2016 INTERNATIONAL...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
